Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Difference between V6 and V8 brakes?
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default Difference between V6 and V8 brakes?
    I was wondering what the differences between the V8 and V6 brakes were in the VP sedan? I'm asking this cos I have plans to drop a 5.0ltr in later, but at the moment I need to replace my pads and rotors and was wondering if I should just have them upgraded to V8 brakes straight away.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    yes,
    V8 brakes are significantly larger. Would be samrt to upgrade to either the Group A brakes or VT brake system. I reccomend twin piston setups on V6's so its mandatory on V8's afaik
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VS Calais
    Apr 2005
    series 1 or 2? afaik series 2 vp got the bigger discs/finned calipers, so the only difference would be the 1" master cylinder, and i *think* v8 execs wouldnt have that anyway.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by friedchicken View Post
    All non-ABS equipt V8's have a 1" master.
    Selling FG G6E Turbo and buying a N/A Supra
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    What about the booster - isn't the V8's larger?
    and 3 Dangerous non ABS VN's
    May 2005
    .....SE Burbs
    nope, pretty sure it was just the MC that the size channged...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Feb 2007
    WA Perth, Joondalup
    So, you're saying that if I have a series 1 then I need the series 2 calipers/rotors as well as the 1 inch MC? And if I have a series 2 I just need to get the 1 inch MC?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    correct. you can also use vr/s v6 calipers. one hint, get the vp s2 v6/v8 ute front rotors. they are 23mm thick instead of the sedan/wagon 22mm. min thickness is 20mm, so you get an extra mm of wear for no price difference from memory. the discs are 289mm diameter i think.
    dba part number is DBA 027 for the rotors.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Pav View Post
    Yes correct vp series2 came standard with v8 spec brakes but do not have a 1inch master cylinder
    VP Exec,Gsx-R 750
    Mar 2005
    Dont mess about with standard V6 or V8 brakes. They are ****. I had standard brakes on my SS and as soon as I could afford it, I put VT fronts on. They are a hell of alot better then standard. And the brakes on my V6 VP are crap. Im just glad I dont need to drive it too often.
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Quote Originally Posted by AirStrike View Post
    no they dont.Mine had a 15/16 another one i have seen had the smaller one too.Both series one VQ V8s.I have also seen a VQ2 V6 with a 1in that is now in my car.
    hakhawk's Avatar
    Jan 2005
    the v8s were probably replaced with v6 ones from a wreckers thinking they were the same thing. the vq v6 probably had been upgraded at once stage.
    but from factory, they got 1"
    VP Executive R-spec
    Jan 2005
    There is a hugeeeeeeee variation in braking performance between cars with the same brakes for other reasons besides the actual stock parts. My V6 and V8 both share the exact same brake setup, everythings the same. 1 inch master V8 spec rotors and calipers BUT my VP has stronger brakes and can stop quicker than a VY or a AU falcon, I know it has a huge weight advantage over those cars but it's blindingly good on the brakes, where the V6 is ****:P clearly something is stuffed on the V6 but the point is just because your car or one certain car doesn't stop well that doesn't mean it's supposed to be like that.
    My boss has an AU wagon that hardly stops at all where my mums AU is well... it could stop in under half the distance from 100 with the exact same brakes
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by adam69 View Post
    I think I read once that the utes don't have a 1 inch master? but I would have thought a VQ should have it. Anyway maybe a few sliped through with the wrong one on but they all should have a 1 inch master
  15. #15
    VT Clubby
    Oct 2004
    Oh and at my mates wreckers there is a VN V8 there at the moment and it has a 15/16.
  16. #16
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by greenfoam View Post
    Are you running the same pads on each one?
    Anyway, VT brakes are good stuff, dang good value. Slight downside of being technically a little bit illegal without an engineering cert, but I've never heard of anyone getting fined/defected for having them. I'd reccomend them to anyone looking to upgrade from V6 gear. Or V8 brakes for that matter, VT's just plain kick the **** out of either of them.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
  17. #17
    88GreenVN's Avatar
    Jun 2006
    The 1" M/C was probably floged and a 15/16" put in its place.
  18. #18
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    r the VT brakes a straight swap over pretty much if u wanna upgrade VP V8 brakes? is there nething else u need 2 change? mayb rotors? ive got my old set from my VT i wanna put on the VP but was told i need 2 change alot and its not worth doin is this a load of ****???
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  19. #19
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    There's not much i think new vt rotors and the need the hubs off vr onwards commodores, calipers, some new brake lines and a vt booster and 1 inch m/c. oh and brake pads
    Feel free to add or correct me if i'm wrong
  20. #20
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by wrx884 View Post
    VT calipers and pads, VT discs, conversion hubs and fresh bearings. That's about all ya need for a front conversion.
  21. #21
    Morton's Avatar
    Fairstar the Funship
    May 2006
    These conversion hubs you speak of... are they an adaptor to make the VT calipers bolt on properly? An aftermarket item, or something you can buy from supercheap/bursons?
    I think some good brakes could be my next upgrade
    The 1972 HQ Kingswood
  22. #22
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Morton View Post
    They're what the disc rotors sit on. So bearings go onto stub axle then hub then disc rotors. the VT style setup don't have the wheel studs in the rotor, they are on the hub instead
  23. #23
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by Pub24/7 View Post
    You dont need VT booster or 1 inch master cylinder. My SS has ABS and a 15/16 master cylinder and it all works fine.
    wrx884, I had to cut my backing plates to allow the calipers to fit.
    Don't know whether it will help you being in Perth, but Slacks Creek Brake and Clutch here in QLD supplied my kit with everything I needed.
  24. #24
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by Hillerus View Post
    So you fitted rears as well yeah? Fronts are dead easy, no cutting of anything required, just a bolt on job.
    Conversion hubs can be bought from mr spares. (as can the whole kit) Or if you're out of your mind you can buy them from harrop for double the price. There is also the option pub24/7 brought up, you can use the hubs from a VR/VS and an adaptor ring to fit VT size discs. Alternatively again, DBA do a VT sise disc with a smaller inner diameter to fit VR/VS hubs. They'd be a special order thing though, doubt anyone would actually hold them in stock.
    Really though, a VT front kit from mr spares or that other freak on ebay (can't remember who but I'm sure there was someone else selling VT kits) represents damned good value and easy fitment. The rears aren't a huge worry if you're just after better braking for everyday driving, but there are options for the rear as well, they just get a bit pricey.
  25. #25
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by pandaman View Post
    Not rears, just fronts, and as I said, I had to remove part of the backing plates for it to bolt up.
  1. what's the difference with VZ SS and VZ SSZ??
    By miniac_beater in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-01-2008, 06:57 PM
  2. What's the difference with VSII brakes?
    By gslrallysport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 06:38 AM
  3. V8 CAI, V6 CAI difference?
    By Avi8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2006, 08:17 AM
  4. Any Difference ???
    By Senatorv8 in forum Car Audio
    Last Post: 18-06-2005, 09:03 AM
  5. The Difference
    By xstatic in forum General
    Last Post: 02-12-2003, 06:09 PM
