Results 1 to 2 of 2
Thread: VN Engine Tuning,can i do it myself???
    VN 3.8 6 CYL
    Sep 2007
    Default VN Engine Tuning,can i do it myself???
    Have a S2 3.8 and wondering if it is possible to tune myself?
    It is running rough and feels mising at idle but has no issues with power and take off!
    Seems to be running on 5 cyl at idle and when i stop at lights then is fine when running.
    Is there a way to tune it without going to a mech?
    Thanks in advance.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Well you can start with all the things that usually cause those issues:
    1. Leads
    2. Plugs
    3. IAC valve
    4. Blocked TB
    5. Reset you ECU
    6. Coil PAcks
    7. DFI Module
    8. Fuel Filter
    try those and see whats you car runs like.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. Tuning LPG on a VK
    By HappyLappy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-01-2007, 11:26 PM
  2. tuning
    By Nathan72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 09:46 PM
  3. Tuning
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2004, 06:04 PM
