Results 1 to 16 of 16
Thread: VN Berlina How big is my fuel tank?
    VN V8 Berlina
    Sep 2007
    Default VN Berlina How big is my fuel tank?
    Don't laugh, this is a serious question.
    I brought my berlina 5 days ago and filled it up for the first time last night.
    The fuel gauge had just started to read on the red, and it took 61 litres to fill.
    So, do i have the 63, or the 80 litre tank ?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Check out the holding straps...if there is rubber around them on the bottom under the tank it is the 63 if there is no rubber around the straps it is the 80 litre..another guide all 80 litre tanks have a plastic stone deflector on the front that goes and around the front corner ..most 63s dont.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by v8slrtorana View Post
    Seeing as its a V8 Berlina it would have the long range fuel tank. 80 Litre it is.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by markovr View Post
    My GTS has a Plastic Stone deflector...I dont think its 80LTR.
    VN V8 Berlina
    Sep 2007
    Ok, thanks for the info.
    Has no rubber straps and has the plastic guard at the front.
    & yes, its a v8 berlina.
    So its a 80 litre then, didn't think it would have 3 litres left, when it just went into the red on the gauge.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, probably 80 litre. I can rarely get more than 55 litres into my 63 litre tank when the gauge reads empty. You may have one of those fuel gauges that goes well below red. My old S1 dash used to give me another 6mm of play below the red bar ^^
    The 1972 HQ Kingswood
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    in the early v8 models there was a 85L tank wasnt there? there is somthing up with my tank coz i think it should be 85L but i can barly ever get over 60L out of it i should be getting 600k of my tank if its a 80L because i do about 12.5/100 or better on average which is 75L for 600k but i'm normaly filling up every 400k and it takes about 50L. is it possible that the pickup is bent or somthing??
    13.3 1/4 exhaust only untuned!
    VN V8 Berlina
    Sep 2007
    Quote Originally Posted by nathans1987 View Post
    Sounds like you tank breathers are blocked. Ever tried waiting a couple of minutes after filling up, then tyring agian? = traped air
    Thanks for the mileage info, at least i got something to work on when i get my oddometer working on the berlina
    My torana uses about 25-30 litres for 50 kays.
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    dont u have 2 allow for expansion in the tank thats y most tanks only fill up2 about 85% correct me if im rong?
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    What year is your SS? Only the real early ones are 85lt, and even then I can't pick the difference visually between it and an 80lt one.
    Selling FG G6E Turbo and buying a N/A Supra
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Joey_18 View Post
    Nah buddy. Perhaps by co-incidence thats the maximum fill for an above ground gas tank at servo's but thats cause LPG expands to 270x its size when it goes from liquid to gas so it obvouly needs the room due to temperature fluctuations.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    i can make my petrol flow right out of the filler if i want... i dont but its very doable!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Nov 2003
    northside brisbane
    Quote Originally Posted by Mack View Post
    I was careful to say most 63 dont have the deflector ..country pak and other selected v6 cars had the deflector but most dont.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by AirStrike View Post
    1990 not 2 sure about the month
    are the breathers like a hose thing? or a valve somwhere ontop of the tank.
    your torana is really bad on fuel lol whats done to it unless you mean 500k's?
  15. #15
    VN V8 Berlina
    Sep 2007
    Default breathers
    Breathers are rubber hoses from the tank or filler tube that generally go to metal tubes the same size that are clipped to the body and go absolutly nowhere. They will always go to the highest point under the body.
    I ment 50kays, its a 355, big solid cam, 3800 stall and 4:11. I race it in the ANDRA Superstreet class. & drive it work every now and then
  16. #16
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    ahh ok there not blocked i just replaced them and they go up to the filler spout thingo.
    Nice! my old man is doing a torrana i wish he would hurry up and finish it. your sounds mad tho
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-09-2010, 12:30 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  4. 80l Fuel Tank Into Vr V6 Sii Berlina
    By satyr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2004, 12:03 AM
  5. Upgrade Fuel Tank, Bs Berlina
    By vsBerli in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2004, 09:13 PM
