Results 1 to 6 of 6
Thread: VP Coolant Sensor
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default VP Coolant Sensor
    hey guys i just got a brand new coolant sensor from holden for my VP.......was just wondering EXACTLY where abouts it is and is it just a "rip old one out and screw new one in" procedure? and will the car drop much coolant during the swap over..........cheers!!
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Check that other thread u just posted in.
    It wont drip much, say 100ml if ur quick.
    Its just a 15mm i think, unsrew it then screw in the new one, n clip on the plug.
    Also take note of where the wireing harness is routed, it took me about 20min to figure out how to get it the right way around soo it all fitted like b4, and make sure you take off the neg terminal, it could arc off the Alt + cable to the block if u dont.
    ________________________________________
    VN calais 91
    Aug 2005
    is this coolant sensor as in the sensor for the temp gauge in the car?
    situated under the alternator?
    92 VP Calais 3.8
    May 2006
    Gold Coast
    there are 2 under there, on the left is the temp sender (for guage) on the right is coolant sensor for ECU
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    all done............cheers for that mate!! also found a vacuum hose had come loose which wouldnt have helped...........runnin like a dream now!
    holden
    Sep 2007
    wheres the vacuum hose to and where are all the vacuum hoses and joins located to in the whole engine bay
  1. Coolant sensor VR V6
    By acclaim94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 12:03 PM
  2. VP coolant sensor?
    By Just_a_stocker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2008, 10:28 PM
  3. where is the coolant temp sensor??
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2007, 01:43 AM
  4. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  5. Coolant temperature Sensor
    By cacaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 11:48 AM
