Results 1 to 3 of 3
Thread: power steering
    holden
    Sep 2007
    Default power steering
    hello im just interested, if the steering was creeking when turning corners and i put a good second hand one on and it fixed the creeking but the steering wheel is still a little hard when turning in carparks why would that be. im using dexron 3 transmission fluid and it is a little throthy, why?, i bought some conditioner, would that fix it or am i supposed to use dexron 2 transmission fluid
    vnss
    Jan 2007
    wyndhamvale vic
    did you bleed the system? maybe the seals in the second hand one are worn out to. you can buy a rebuild kit frm hldn fir about $20 or $50 for v8 pmp and a couple of hours you can reco it yourself.
    holden
    Sep 2007
    i just let the oil out the bottle itself thats it how do you bleed the system do you just let the fluid out of the power steering bottle and that be it or how do you bleed it properly and all the o rings have been replaced. can you use dexron 3 transmission fluid or do you have to use dexron 2 transmission fluid
  1. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  2. Power steering Vs. manual steering?
    By cruzncommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2007, 07:45 AM
  3. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  4. power steering!!!
    By munchmunchrotors4lunch in forum V6 Development And Modification
    Last Post: 25-10-2007, 07:57 AM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
