Hey
Started my VN this morning to do a service etc I had a leak which I thought was pwr steeing fluid because I had to keep topping up as it was making a noise when steering.
Anyway to cut a long story short, when i was moving it to put it up on the ramps in my garage something blew & it started pissin out pinky & reddish fluid everywhere so much it shot up all under the bonnet fuc&in everywhere!!All over the rd (neigbours are pissed)
I thought it was a leak in my pwr steering pump but I think it could be worse in that when I started it up next I put it in gear & it wouldn't drive or move anywhere just revved out. Started blowing smoke & **** and more pink fluid was coming out the botton & sparying everywhere. I checked the trannie level & its bone dry. WTF has happened? It is a seal somewhere? Is there any connection to the pwr steering pump & the tranny?
Please help..
No connections between the p/s and trans but I would be checking the trans cooler lines.
def is tranny probs. check the trans seals and see if any are worn or busted. will prob have to get tranny reconditioned.
Found the problem, turns out to be a hose that runs to the trannie pressure guage. It has popped off the t-piece. So was a simple fix.
Whats the best way to clean up trannie fluid?![]()
Try some truck wash,make sure its biodegradable or ya neighbours will have ya knuts.
Phillip![]()
they prolly already pissed ! i was gonna try hydro acid 1:5 mix tomorrow.
id be killing ur neighbourssifnt get pissed off for that
could be worse, ill tell u a story
once my mate called me up and hes like i think i over filled my oil...
he gets to my house in his R31 skyline
and hes like i went to do a oil change but i forgot to drain it first...
he pulled up and oil was surging from everywhere... and left a puddle as big as the car.. he put in something like 8L-10L of oil in a RB30..lol
trans pressure gauge??? custom spec because i dont remember them comming out factory like that
