Results 1 to 25 of 25
Thread: welding exhast!!
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default welding exhast!!
    what would i need to disconnect to weld the exhast as i want to put a chrome tip on and i dont want to fu#k up the electrics...lol
    cheers all
    VN calais 91
    Aug 2005
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    thanks for the reply
    yeh was thinking the battery but would it also be a good idea to disconnect (unplug) the ecu (computer)??
    thanks
    VN calais 91
    Aug 2005
    it wouldn't hurt (seeing as the VN, especially the calais models) have so much electrics
    but i had my muffler tip welded on with just battery disconnected
    as long as you earth the neg of the welder, you should be right
    VP Executive R-spec
    Jan 2005
    I've done a fair bit of welding on mine with everything still connected, no problems so far
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    VP Executive R-spec
    Jan 2005
    Yeah in theory all the powaaaaa from the welder should go from the earth to the tip and no where else, you shouldn't ever weld through a bearing or any place with a join that you don't want to stuff up so just put the earth close to and on the same part that you are welding and it should be fine
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hey thaks for all the replys
    well the battery is the first thing i would dissconnet just to be safe
    if i get around to doing it anytime soon ill let yaas know how it turns out (and maybe a pic lolz)
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    It is good practice to disconnect and remove the computer from the car. Leaving it in probably wont cause any problems but for the 5 minutes it takes to remove it why take the risk.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Never disconnected anything... No exhaust shops do either...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    cant believe this,i hope you arent professionals giving this advice!!. why wouldnt you disconnect the battery? - a very big risk if things go wrong
    - how would you explain to the customer that their car has to be taken to holden for a new computer? - there goes all your profit for that and the next job.
    and all for the sake of undoing the battery!!
    following welding principles, the current will follow the path of least resistance, so as greenfoam said "put the earth close to and on the same part that you are welding"
    so since you are welding the exhaust put the earth clamp on the exhaust (preferably the same section)
    and where you are welding give it a rub over with scotchbrite to remove any rust and soot, this will reduce inclusions and give a stronger weld.
    any birdsh*t welds are unacceptable also
    - do it once do it right
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'm a welder by trade i know how to weld and do good qaulity welds. I weld alloy cylinder heads and know whats is acceptable and what is not. My point was i have never-ever seen an exhaust shop disconnect the battery or ecu. You think that would take the risk if they knew it could cost them $1000 to fix a customer's car?
    If i was doing it my i would disconnect the battery and make sure both earth and positive were not touching the the body (creating a circuit)
    VN calais 91
    Aug 2005
    maybe said weld shops are too busy, employ apprentices or just choose to play roulette with your car
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hey i forgot to mention that i only have a arc welder.. would it still be alright to just dissconnect the battery only or?
    and thanks for all tha help
    cheers
  15. #15
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes disconnect the battery have fun welding it with an arc i suppose you won't have to weld all the way round a bit on each side will hold it on well enough.
  16. #16
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
  17. #17
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh thats the only prob as a arh welder may blow holes in it..........lol i may pop rivet it on but i dont want to have the pop rivits obstucting to exhast flow...JK (its only stock system) lmfao!!
  18. #18
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hey havent welded it on yet but was wondering how much and exhast place would charge to do it ??as like i said i only have an arc welder and dont want to fuc# up the electrics..................however i may try it but dont want to (also) blow holes in the metal lol
    cherers
  19. #19
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    17 years in the exhaust industry and never disconnected a battery yet. Never blown anything up either. Just put the earth as close to where you are welding as possible.
    Visit my Facebook page
  20. #20
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by timmy_tam View Post
    Interesting, considering all 4 of my cars have been done by the same workshop - which are one of the most well known in the Northern suburbs - and I have never seen them disconnect a battery. Everything from trucks, my SS, skylines, orginal XW Phase II, etc.........
    Maybe your places are just scared of their lack of experiance......
    Selling FG G6E Turbo and buying a N/A Supra
  21. #21
    Aug 2004
    ull be fine, its not going to blow anything up **** u can weld things while holding them its not like ur going to get a belt off it let alone damage ur car
  22. #22
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Just do it already.....as was stated, put ya earth close to what your welding and away she goes.
  23. #23
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    thanks for all the replys ..........................will try and do it on the weekend
    cheers all
  24. #24
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    exhaust shops normally pop the bonnet and clamp on the surge guard between the battery terminals instead of taking them off if you dont disconnect the battery you stand a high possibility of stuffing the alternator i allways disconnect the ecu after my mates ecu got toasted when his mate welded a hole in the exhaust
  25. #25
    VX Executive Wgn, VP Sedan, V6 Ride on Lawnmower
    Aug 2007
    blow holes? **** that. turn the amps down and get smaller rods.
  1. TIG Welding
    By Wrayza in forum General
    Last Post: 22-12-2006, 08:01 PM
  2. s1 and s2 exhast manifold
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 09:58 PM
  3. welding
    By vicarious in forum The Pub
    Last Post: 02-11-2006, 06:34 PM
  4. welding??
    By V3N0M in forum General Discussion
    Last Post: 17-06-2006, 01:29 PM
  5. Exhast in VY II Calais
    By barbs in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2006, 06:17 PM
