Results 1 to 10 of 10
Thread: Grinding in the steering wheel
    VN Calais 5.0l
    Jun 2006
    Default Grinding in the steering wheel
    Like it says one day my steering wheel started grinding, theres a little switch that is touching a plate that connects the horn to the... umm horn. its causing the grinding sound and also putting little brass shavings everywhere, however if i pull the little switch away from the plate the horn doesnt work anymore
    How can i keep my horn working and stop the switch from grinding down any further? it has to be a metal to metal contact i think so i cant rubber it up. Lube?
    Ill post some pics if u dont get where it is???
    This guy describes the pin thingy too. Horn
    But he has a different problem.
    VN Calais 5.0l
    Jun 2006
    Photos of the little brass contact touching and then touching. Soz about the quality too
    Just covered it in WD-40 let it dry a bit and then did it again. Its improved slightly but its still there. Anybody want to comment please?
    Attached Thumbnails Attached Thumbnails Grinding in the steering wheel-photo-0360.jpg   Grinding in the steering wheel-photo-0361.jpg
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    The little copper contact is spring loaded, so it souldn't be scraping against the wheel. The spring could be stuffed, could need some WD 40 or replacing.
    Also the brown plastic part that holds the copper contact contains the the non moving part. Try checking to see if its a tad loose.
    VN Calais 5.0l
    Jun 2006
    But the copper part needs to be touching the wheel so that the horn works ill play with the plastic tho, thanks for replying
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    car
    Jul 2006
    greensy, melb
    yeah u usually find alot of car yards put grease on it so it stops making sounds
    "A life lived in fear is a life half lived"
    Aug 2007
    S/E Suburbs
    Here is a diagram of what i was talking about. Its a bit rough, but u get the general idea.
    Lets us know if your still having problems.
    Attached Images Attached Images
    Jan 2005
    Quote Originally Posted by jas98 View Post
    needs a bit of greese...seriously try greese lol may work may not
    i'll 2nd that - put a small amount of grease on it.
    Also check that the copper contact hasn't snapped off causing a rough edge.
    Aug 2007
    S/E Suburbs
    Had a look at mine today, started making a noise. Fixed mine by gluing the copper part that is in the brown plastic part. (unplug it first, then apply a little bit of glue) If you can pull the entire assembly out, then thats your problem right there, the back part where the wire plugs in needs to be stuck in place to allow the spring loaded bit to work properly.
    Don't do what i did first time it played up, i pulled the whole thing out and replaced with a screw.... Not a whole lot of fun trying to clean all those shavings out from the column.
    If your still having problems, let me know.
    VN Calais 5.0l
    Jun 2006
    Haha mad diagram good work It helped heaps tho, i put some wd40 on it yesterday and u can barely hear it at all anymore so im going to leave everything atm but if it happens again ill whip out the glue cause the parts in your diagram that arnt supposed to be moving are moving
    Thanks yall!
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  3. Front wheel grinding noise
    By clintonhadenham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-08-2005, 06:21 PM
  4. Replies: 1
    Last Post: 18-04-2005, 02:32 PM
  5. Steering makes grinding noises
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2004, 02:59 PM
