Results 1 to 4 of 4
Thread: air con problem
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Question air con problem
    hey put me air con on today but noticed that my compressor did not engage the clutch.....however the engine fan came on but like i said the compressor didnt do anything.
    me (and me dad) bridged out the low and high pressure switchs but the fan is the only thing that comes on!!
    air con has been working prior to this problem and was cooooll. but not cold and certainly not warm
    also when the air con is switched on and the fan comes on the fan kinnda dies down and back up but very quickly (if u know what i mean)...kinnda like when there is a bad connection?
    and when it does this the fuel pump relay (under bonnet) goes tick..tick..tick..tick.......but engin performance is still great, this only happens when i plug in the relay for the air compressor
    i did replace me pully bearing in the compresson not long ago but it all worked after i did that lol
    with air compressor relay out i put the air con on and the fan cuts in and the fan runs fine...................ITS A WEIRD PROBLEM lol
    cars a VN 1988 and has the upgraded gas system in it
    any help would be great
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yay got it working (for now lol) however the drain hole under tyhe car for the water to come out (for the air con) seems to be blocked as there is no water dripping when i stop lol
    VN S2 V6 Berlina
    Apr 2007
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    well to be honest me dad (hes an electrician) tested if there was any power getting to the switches and there wasn’t so he played around with the wire/s on the switch near the radiator and it started getting power swell as the other one(confusing as we bridged the switch yesterday and the fan was the only thing that came on).... so im guessing there is/was a bad connection at the switches and was trying to trigger the clutch and couldn’t resulting in the fan dieing down and up
    We made sure the compressor clutch was working buy feeding 12v to it
    however when me dad checked if there was gas in the system (by pressing the valve on the cylinder thingy) there was gas in there as there was allot of pressure but there was a whitish foam stuff that came out like water when its mixed with oil???? So tomorrow im going under the car to check if the drain plug is blocked
  1. Amp problem
    By Gunns VC in forum Car Audio
    Last Post: 16-10-2007, 03:33 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. Another Problem
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 01:03 PM
  5. Problem after problem!!!!!
    By Swerve103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 06:24 PM
