Results 1 to 4 of 4
Thread: problem with vp ss
    vs executive s2
    Jun 2005
    Default problem with vp ss
    ok i have a problem with my vp ss i changed the ignition barrel and put a new one in and started the car fine every thing worked then i degreased the engine bay started it everything worked then 4 days later i tried to start the car and when you put the car on to assentials none of the engine lights come on and the cd player does not works and the alarm is not working there for no fuel is getting to the engine so it wont start is my problem with the alarm or is it with the electrics can anyone help cheers bjk87y
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Some water may have gotten into somewhere. I would check the battery connections first, then the fuseable link. Then go over all the fuses. Pull the harness plugs apart and blow them out, or spray a bit of WD40 in them.
    Does it actually turn over?
    Visit my Facebook page
    vs executive s2
    Jun 2005
    yeah it turns over but wont start as my alarm has a fuel switch on it so it does not get fuel so wont start
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Water may have gotten into the alarm and shagged it. Can you disable the alarm to see if it runs?
  1. Amp problem
    By Gunns VC in forum Car Audio
    Last Post: 16-10-2007, 03:33 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. Another Problem
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 01:03 PM
  5. Problem after problem!!!!!
    By Swerve103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 06:24 PM
