Results 1 to 4 of 4
Thread: Dumped exhaust
    nofords Guest
    Default Dumped exhaust
    Hey all i was just having a look at the "modification rules" for qld and it says you can have your exhaust finish at the end of the floor pan i am guessing this is just infront of your diff??? Ive got an idea for an exhaust just need to get a few things sorted out. any help would be good thanks. Nic
    nofords Guest
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Slip Guest
    Wink YES You Can
    hey ive seen it done, actuallt ive had it done and im in a state where its not legal, some exaust places will do it but u cant say their names, thats why i am not telling, mine was dont on the curve where the pipe bends up over the diff and it sounds BEAUTIFUL. The only prob is that u need a 2.5 sports exaust to make it sound good otherwise u r wasting ure time. Where i got it done they cut a hole, welded a samll peice of pipe on the hole then welded a flange onto it. They then gave me anouther flange that had a bit of flat welded on the whole in the flange so then i chould bolt it on to the flange welded onto the exaust so it would go back to quite, because inside the cab is loud and i recomend having the flange screwed opn when doin long distances, apart from that going down town u get a beauti### sound that does TURN HEADS. Sounds better when you are at low revs in gears.
    While im at it u might be able to help me with what gives more power, A POD filter or a ss cold air intake.
    Thanks hope this helps,
    Late... Slip
  1. vn v6 auto,ss kit,ss interior,17z,dumped,great car
    By lukemorrison in forum Vehicles For Sale
    Last Post: 09-05-2007, 04:10 AM
  2. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  3. VN = dumped
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 02:17 PM
