Well I want to get my engine bay smoothed hopefully next weekend. Now what is the best way to firstly fill the holes? Im guessing weld then grind them smooth.
Also secondly what is the best way to remove the standard dent on the passenger side, also smoothening off where the ignition module was along with the mounts for the relay box and so forth?
The bay is already prepped, wiring removed and almost finished relocating it. Cut off the alarm, relay and cruise control mounts and grinded them smooth. So just need to get it filled and smoothened and it can be primed for paint
