Results 1 to 9 of 9
Thread: anyone got any good trick with lining up engine mounts?
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default anyone got any good trick with lining up engine mounts?
    im in the process of dumping my engine in, can only seem to get 1 side in, last time i changed engine mounts i ended up removing the aircon and that bracket and bolting the bracket up after
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    last time i did mounts i put the mount in and then bolted the bracket to the block
    Body by Holden, Soul by Brock
    the Legend will live forever
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    When putting a V6 in you get one side in then rest a little bit of weight on the other side and using a pry bar lever the other side in. You need to sort of twist the 2 studs and get one in then twist the opposite way to get the other stud in. Its a bit of a mission but it can be done quiet easily that way. Its the sort of thing that once you have done it once it is something you wont forget how to do. I have done many a V6 engine change and this is the way i do it, hasnt failed me yet.....
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    maybe tommorrow, after i get it bolted in to the mounts, just gotta connect a few wires, do up torque converter bolts and dump... we'll see
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    im thinking now i might aswell rip the aircon off and insert the mount into the kframe and then bolt up the mount+ bracket to the block... sounds easiest to me
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    My WAY!
    Step One: get Right hand ride of engine into position
    Step Two: Lower Engine slightly so that the left hand side is almost touching the K frame
    Step Three: Tie a piece of thin but strong rope around the mount and run it under the car to the opposite side(so if your puttin the drivers side in, run it to the passenger side)
    Step Four: Slide a rod through the robe so its like a water ski
    Step Five: PULL!!!!
    Step Five b: Get someone else to lower the engine so it drops in
    Step Six: Put all four nuts on but only a few turns
    Step Seven: Raise Engine once again until it reaches the nuts and wont go any higher
    Step Eight: Pull rope out
    Step Nine: Lower engine
    Engines IN!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    it was a pain in the ass but i had to remove aircon and bolt the drivers side in first then bolt up the, it was a bastard and took a few hours but its finally in!!!! just gotta bolt up dump pipe / torque converter and shes all ready to go
  1. engine mounts
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 05:28 PM
  2. VR engine mounts
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2007, 10:29 AM
  3. Engine Mounts
    By donz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 12:13 AM
  4. Engine MountS!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 02:43 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
