Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Upgrading Brakes
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default Upgrading Brakes
    I would like to upgrade the brakes on my VN S1 V6.
    Presently I have the standard master + booster.
    How would I go about fitting up VT spec brakes? What would I need? I know I would need a 1" master, calipers and rotors but what else is required?
    What do you need to fit up a VT rotor to a VN? Also, does anyone know of anywhere that sells complete kits around FNQ?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    the rotors need a hub adaptor, which from what i've heard means you need a engineers cert (in vic at least).
    also i think you'll need new lines. stacks of kits on ebay. not genuine VT, but VT spec.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Do a search, there's an absolute ****load of information on the VT upgrade, including a thread that should be in the first few pages of this section.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I do the RDA upgrade kit.
    Rotors, hubs, new calipers, pads, longer braided lines and fluid. $750 plus shipping.
    Visit my Facebook page
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A full kit for the brake conversion, without the 1" master cylinder + booster, will set you back around $700 if you fit it yourself. Just to give you an idea.
    The 1972 HQ Kingswood
    MasterOfReality's Avatar
    MasterOfReality is online now Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Engineers is required as VT brakes weren't an option on VN's. Duh.
    I was going to do this on my VP but the idea of hub adaptors just didn't sit right with me and I kept hearing bad things about how spongy the VT brakes were, even with a 1" master cylinder (my car is a V8).
    $700 is the average price for the VT kit.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by MasterOfReality View Post
    Hub adapters arnt a problem at all, the shims for VR and VS are the real dodgy ones. As for the spongy pedal, if you have a 1" master it's not going to be that bad. If you really don't want any do it correctly like I have, VT master and booster along with a VS reservoir.
    Selling FG G6E Turbo and buying a N/A Supra
    Feb 2004
    Where the mines are
    Quote Originally Posted by AirStrike View Post
    How much did that set up cost you?
    I'm trying to figure out if that set up plus engineers is still cheaper than trying to find VN Group A / SV5000 / VP GTS brakes, which don't require an engineers cert.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah i'm getting a genuine full vn group a setup for 950, just couldn't be assed dealing with engineers cert. just need a 1" master cylinder.
    Feb 2004
    Where the mines are
    Quote Originally Posted by pow3rslave View Post
    I have seen kits on Ebay that claim to be the same as VN Group A, but come with hub adaptors? WTF is going on there? I thought the genuine stuff was a bolt on item?
    Did the ones you got come with hub adaptors?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The problem with genuine group A brakes is the rotors are ridiculously expensive. If you have to replace the rotors at any point in the cars life it will cost you an arm and a leg, unlike the VT rotors.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I do the VT upgrade kit like I said earlier, $750 with standard rotors, $825 with slotted.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Damn straight, the new hubs are not some dodgy adaptor, or spacer, they're a whole hub assembly. What you're doing is converting it to a separate hub setup like on the VR/VS but with the correct diameter to fit VT discs.
    There is another option for people doing the conversion on a VR/VS, they don't have to use the spacer rings, they can buy DBA040B dics, they are VT size discs with a suitable inner diameter for VR/VS hubs. Not really relevant though.
    I didn't find spongy pedal to be a problem with my brakes, yes it's softer than before, but that's about it. Everyone who's driven it has no problem with the brakes. I've got a modded VT master here, but I'm not sure whether I'll bother fitting it. I've said it before and I'll say it again, they're a brilliant value upgrade.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    i have the vt brake upgrade on mine, with curved slotted rotors and braided lines, but am still yet to team them up with my 1" mc and rear curved slotted rotors, the brake pedal is a little softer with the 15/16 then before but it pulls up alot quicker, no fade anymore(i think thats what its called??)
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    With a 1" M/C you will have better fluid volume so the brake pedal will be firmer. The slots on the rotors eliminate fade because the gas build up from the heat is dissipated by the slots.
  16. #16
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Its only $480 to get a certificate as long as you have the standard specs vrs new specs, ur laughing. Im gettin my VZ upgrade engineered in a few months.
  17. #17
    Feb 2004
    Where the mines are
    Gee thats a bit more than the $180 the engineer wanted in NSW to write me a certificate for the VT's I was thinking of putting on.
    I think I might keep looking for the VN Group A brakes then, no engineers certificate required for those, but I'll try to find out how much it costs in QLD.
  18. #18
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    can't understand why that'd be. vn group a's should be a straight up bolt on for a vn/vp. haven't got mine yet, but i'm in talks with the guy. no adaptors mentioned, but these are genuine.
  19. #19
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    the ebay stuff is mock up group a stuff which still needs hub adapters...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  20. #20
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    If you are going vt/x master/booster I can supply any of the parts you need from the modified bracket to modified booster to complete setup .....a few blokes on this site are using some of my parts and noone has sent anyone around to rough me up because it was dodgy ....pm me if you are interested.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  21. #21
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Ok, is the following upgrade kit the sort of deal that one would be looking at coupled with a vt master/booster?
    COMMODORE VB VC VH VK VL VN VP VQ BIG BRAKES GROUP A - eBay Commodore, Holden, Car Parts, Cars, Bikes Boats. (end time 15-Sep-07 10:02:56 AEST)
    I do realise you could do it a bit cheaper if you sourced all the parts second hand or something but hmmm, it seems rather tempting
  22. #22
    car
    Jul 2006
    greensy, melb
    u guys that do the vt upgrade for ure v8's, do u use just the v6 brakes or the v8 ones?
    "A life lived in fear is a life half lived"
  23. #23
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by mulligan-can View Post
    This is the same type of thing I do for $820. http://www.rdabrakes.com.au/download...e_Brochure.pdf Level 1 kit.
  24. #24
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Oh. Cool. Is that your site/company?
  25. #25
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Thats my supplier. I'm an independent wholesaler.
  1. Upgrading Disc Brakes
    By vn88calais in forum General
    Last Post: 22-06-2006, 08:11 PM
  2. Upgrading.....
    By Kytro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 02:36 PM
  3. Upgrading VN ECU
    By jamieaus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 07:38 PM
  4. Upgrading
    By VROCIOUS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2006, 08:53 PM
  5. vt upgrading
    By phoenix_984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2005, 08:30 PM
