hi guys,
I got myself some VR door pods for my VP Calais.
I was wondering if anyone could tell me what I need to do to get em in there or if you can give me any tips before i go and start cutting my doors up.
Any help will be appreciated.
PS: I tried searching but couldn't find anything.
The best sorta way to do it is:
Lay the door trim down and place the pod ontop
Trace around the pod with a lighe pencil whihc can be erased.
Measure out the position of the holes and mark them onto your trim
Take the pod(black part) and place it upside down where it would normall sit within the trace.
Trace around it
Cut that out
Drill all the other holes
Screw pod to trim
Reinstall everything...
Its kinda tricky to do, bit of trial and error i guess....
aZk.
Finished putting them in last week..
I'm pretty happy with the result.
Despite the difference in colours it doesnt actually look that bad 'in person' same colour as the carpet at the top of the door and my seat covers so yeh.
Just thought I'd bump this thread up as I'm doing mine tomorrow or Wednesday
I've marked out the holes, etc from the VR trims I got the speaker pods from but was just curious how easy it is to cut the door trims and if a normal jigsaw blade will do it fine ?
If ignorance is bliss why aren't there more happy people around ?
i just done mine the other week, i used a jigsaw with a med\fine blade on it. worked fine.
if you are going to put 6.5" fronts in like i did, they dont fit in the black plastic door pod thing, so make up some spacers using MDF
I just got a VN/VP HSV +6, thought it would need to do the same but appears the holes in the door are already there and i just need to install the Pods, any word on where i can get some?
you can get a pair off me if you like.
ebay is always there![]()
How much do you want them for? Where are you located?
