Results 1 to 4 of 4
Thread: engine light
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default engine light
    Today i started up the car in the morning as per usual. got 1 min down the road and noticed the engine light on. was running good, so i pulled over and almost as soon as i pulled up it cleared.
    So i continued to Tafe and keeped my eye on it. Didnt do it again the rest of the day coming home either.
    Got home and i just done a quick code check. It spat 34 (Map sensor voltage too low), Soooo i checked the map sensor, part of the hose was a little frayed but not enough to leak, and the connector wasnt loose etc.. i since cleared the codes (ended up breaking the main fusible link, DIDNT KNOW IT HAD BOLTS IN IT!!!!) anyway 5 bux later its all good, should i wait and see if it does it again before investigating further?
    im going to replace the hose ASAP and check error codes again next time i drive it.
    also do i have to remove the main fusible link, or just the engine fusible link to clear the codes? or it it easier just to disconnect the battery?
    Power is measured in DECIBEL
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    heh yeah i was reefing on the main one. not knowing it had 2 bolts in it! which ended up breaking it. then i couldnt get the barstard bolts out, they were friggin tight!
    was looking at the gregories just then, which i should have looked at before. It has an ENG COMP fusible link, which mine doesnt have, its just a spare blank, weird?? so i'll remeber just the engine one for next time! thanks
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    To clear my codes (VS) I pull the 20 amp engine fuse, turn the key on, turn off, replace the fuse and then the codes clear.
    Visit my Facebook page
  1. engine light
    By DST300 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2008, 05:29 PM
  2. engine light
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 12:11 AM
  3. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
  4. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
  5. engine light comes on
    By kuulbots in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2005, 11:18 AM
