Hi i went to deerparkk wreckers the other day and saw an level 3 cluster in a vp commodore. Asked the dude there and he said it wouldnt fit into a vn cos of the extra wirings. But i know itll work well atleast the gauges will cos i heard and read round and seen ppl say it will fit But u gotta modify it to make the lcd screens to work. My question is will that vp cluster work in my vn? Also how hard will it be to make the clusters work? Thanx in advance
The one out of the VP will work. You will need to get windscreen wiper switch block from the car the level 3 cluster came out of too. This thread should tell you what you need and how to wire it all up so everything works.
Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
i got a Stage 3 cluster with the switch block and extra wires from a vn, will this one fit my VP Commodore ?.
VP's ARE THE BEST
Are you up for a bit of reading? see this thread->
Converting to a VN Calais dash
I did a how to in it for vp base models with no bcm
Originally Posted by Smidy
My VN has a VP Calais lvl 3 cluster, and the VN calais trip buttons. Just make sure you double check the wiring from the cluster to the diagrams provided.
Now tell me who thinks this is awesome, i love it but i wanna ask around and also do you reacon brand new for $88 is a good price, check it out on this link VN-VS L3 FASCIA CALAIS/HSV/BERLINA/STATESMAN/MALOO/VR - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 16-Dec-08 22:06:13 AEDST)
VP's ARE THE BEST
Can someone help me ?. i converted to a level 3 cluster but when i first take off the speedo doesn't kick straight in, it will kick in by itself after awhile or if i tap the dash it picks up, can someone tell me what it is ?.
VP's ARE THE BEST
if it was fine before cluster swap then it likely the cluster
yes that should work would be cheaper to do it yourself but if your no good with a so;dering iron get someone else to fo it
