Results 1 to 4 of 4
Thread: VS wiper arms
    VT 5.0L
    Jun 2005
    Default VS wiper arms
    Is it possible to hook the loom up for a vs wiper/indicator arm assembly to a vn?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    You mean the switch arm on the coloum yeah?
    if so, yes, i have one
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    May 2005
    .....SE Burbs
    OK, had ot find an image, thanks to markovr, he made this up and it works a treat, you need to buy a relay but still.
    Youll need to pull the PCB out of the switch block, i suggest going to a wreckers to get one as unless your doing a dash converiosn like i did, youll need it.
    Its not hard, i did it...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Try this thread VP Calais (level 3) Wiper Switch It shows how I mounted the daughterboard from the switchblock in a jiffybox and ran wires to tee off the original wires at the switchblock. The relay is less than 4 bucks from jaycar and is glued to the board to make it a unit before mounting it in the box and running the 6 wires to the various places on your original loom.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. How Do I Remove Wiper Arms
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2006, 09:04 PM
  2. Painting window wiper arms
    By dawg in forum General
    Last Post: 06-12-2006, 05:42 PM
  3. Please Help! Cant remove Wiper Arms!
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2006, 11:08 PM
  4. how to remove wiper arms????
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2005, 07:42 PM
  5. Windscreen wiper arms
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2005, 01:26 PM
