Results 1 to 2 of 2
Thread: Speedo fault
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    Default Speedo fault
    hey all
    I have a question
    I have an L3 cluster in my ute and the speedo is playing up,tried cleaning the contacts and tightening nuts.I contacted the guy i brought it off about having a look at it,i just wondered if i can put the old L2 cluster back in to test if its the L3 cluster at fault or something else.
    Phillip
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You shouldn't have any problems putting the L2 cluster on there if it's the original cluster anyway. Is your dash wired up to accept an L3 cluster? I'm no expert, but I know there's some modification that must be performed to correctly run a L3 cluster on an L2 dash.
    The 1972 HQ Kingswood
  1. Speedo Fault
    By PRH in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2007, 09:57 AM
  2. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  3. srs fault
    By btsmash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-02-2006, 08:20 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. speedo and tacho intermitent fault!
    By auschev in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 11:42 AM
