hello im wondering how do you remove a IDLE SPEED/IDLE AIR CONTROL/STEPPER MOTOR and reinstall another one in a v6 vn/vp as im interested to find out. and where is the idle air control motor located to and
how long and hard is it to remove manifolds and renewing gaskets and how do you clean throtte bodys in v6 vn/vps
Howdy homer
Removing the throttle body + elbow is simply a case of undoing the bolts that hold them in place (three for the throttle body, and two for the elbow?), and removing the associated vacuum hoses. If you wish, you can label them - but it's all pretty straight forward.
To remove the IAC, you'll need some torx screwdrivers - although I find a small allen key fits the screw heads just nicely. I think there's one on either end of the IAC from memory, and that should remove the unit.
To clean out the TB and elbow, just lather them in some carby cleaner and let them drip-dry. $10-$15 from any auto store.
Gaskets are cheap too - ensure you have the correct ones before you begin because you'll likely break one or two when you disassemble the whole lot.
All up, maybe a two hour job if it's your first time and you're not too confident. Just don't go removing the throttle spindle, because if you **** it up, it's likely you'll never get it back on correctly by yourself![]()
I know I couldn't!!
The 1972 HQ Kingswood
can you give me a guide on removing the idle air control valve motor and what gaskets are you talking about and where and wheres the throttle spingle your talking about and is that located on the throttle body itself
and how long and hard is it to remove the manifolds and how do you do it.
also how do you tell if the rocker cover gaskets need replacing
Have a look at this thread. Might help you out![]()
Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
is it just me or does this read like the similar posts of 12000 14000 17000 or whatever, these questions have been asked and answered
I don't fear the fall, I fear the sudden stop
