Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: how to program a eprom
    Mar 2006
    Default how to program a eprom
    well ill be receiving my eprom burner tomorrow and it says it comes with the Programmer software 0.97g and 0.97ja. how easy is it to burn the chips, im under the impression that you need to change some paramaters for different types of chips, ill burn the first tune onto a 27c256, and i have flashable 29c256 on the way,
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    i would have thought u would have learnt the basics before you purchased the burner..........i dont reckon you would get many answers on here mate (i could be wrong) because most of the people who know how to re map chips do it for a small fee for people therefore wouldnt tell alot of other people how to do it.........doctor bob and greenfoam have some very nice chip tunes i have heard all about foamys and i have a doctor bob tune in my VP...........*high five very niiiice*
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    me, greenfoam, and most of the other diy tuner guys are more than willing to help people out. we dont care much for charging people for something thats able to be done for free with a bit of searching.
    http://forums.justcommodores.com.au/...t-install.html
    check out that thread, i cant remember if theres any info on that thread about burning, but its quite simple. choose the correct ic form the list, set the dip switches to correspond to the pic in the program, place eprom in socket, load tune, burn.
    Mar 2006
    Quote Originally Posted by hakhawk View Post
    cheers mate, i just thought you needed to define a start point on the actual chip to burn the tune, dont mind me. probly gettin things mixed up.
    to the other guy, i have been learning, ive been doin alot of reading on the thirdgen forums, for the past 4 weeks, ive read all the threads on here, and on street comm, but seeing as i didnt find any info on actually burning the chip, i thought i might ask anyway, ive set up some tunes my self, changed a few things more spark advance, slightly richer a/f up in the rev range etc...... but i also need to ask questions to learn things, ive made my memcal socket and got a few blank chips.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Dont worry rabid wait till spanners or greenfoam sees the thread he'll tell how to set the jumpers and what not
    hakhawk's Avatar
    Jan 2005
    ahh, didnt take notice before, youve got a 256 ic. ok, easiest way is, if you're using a vn/vp tune, just use tunerpro and stack the tune ontop of itself before you burn it. then just burn the whole file to the ic and you wont have to worry about offsets.
    Mar 2006
    thanks for that buddy, thats what i ment. with the stacker in tuner pro. it says bin size 16kb, then chip size 32kb, should this be changed to 256?, also block size is 32kb.
    hakhawk's Avatar
    Jan 2005
    ok,you're lucky, i did this for someone else the other day(havent used a vn tune in like a year, vr manual tunes for me these days)
    bin size 16kb
    chip size 32kb
    block size 16kb
    choose your output file, then choose the same bin for both positions, click stack and that bits done. then using the burner program, open the bin you created and burn it.
    VP Executive R-spec
    Jan 2005
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    hehe ok in tuner pro
    under tables and functions
    Fuel map
    F29H: Volumetric Efficiency (VE) as a function of MAP/PSI and RPM
    Spark map
    F1 SAMAIN: Main Spark Advance vs MAP and RPM
    you said you wished to make it a bit richer up top? this would be the place to do it and make advance the spark a little to squeaze some more power out
    but have you got your self all the definition files etc? also ive got some SV3800 tunes if you want to look at them, are you tuning a 6 or 8 aswell?
    VP Executive R-spec
    Jan 2005
    I dunno what thread you are reading man but when I read it he said he had allready changed the spark and fuel and just wanted to burn it :P
    Mar 2006
    well i got my burner done it all.. set jumpers, set dip switchs, got my IC, whacked it in... stacked my bin. it verifyed the chip fine, and said it was blank. i pressed program.. instant error that said error at 0x00000 then CHIP = 0x00 buffer = 0x23, then i do a blank check and it says chip is not emty, also do a verify and it comes up with the same error, whats the go
    also i got a UV light that goes into a lamp, would this erase a chip?
    VP Executive R-spec
    Jan 2005
    I dunno what went wrong man, but in these cases it's norally a bad connection, bad jumper setup or chip in upsidedown or something like that, everyone figures it out in the end, give it a day or two and you will be burning like a champ you need a uv light that makes you blind in about two instants to erase a eprom so I hope you don't have one in a lamp for your own sake
    Mar 2006
    Quote Originally Posted by greenfoam View Post
    i double checked the jumpers and if the chip was in upside down or not... it was all correct, must of been just one of those things.. not happy tho. gotta wait a week or 2 for my flashable ones to arrive so this was the only chip to work with. o well.. under programmer settings. it says check type should that be 16 bit add?
  15. #15
    VP Executive R-spec
    Jan 2005
  16. #16
    Mar 2006
    Opp oh yeah that's 16 bit add on mine
    no worrys thanks buddy.
  17. #17
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    did I here someones burning a chip im here
    you didnt read the chip did you i have some here that wont burn two i read with the willem never burnt again zapped you must have the burner connected and the software open before installing chip too this cooks them if you put them in first i dont have a willem with jumpers ive got LEDs and push button switches and the switch block so youll have to bare with me on the jumper settings.some memcals ive got off people never work must get the odd zapped one or people have opened them up and touched stuff.try not too touch the pins if you can help it i have a direct earth to a ground stake beside my pc so i can touch them no problems.what are you erasing with i tried allsorts of bulbs and now have an eraser that cost $30 nothing else will do really.
    what did you have set for hardwhare up the top does it say pcb3 or willem
  18. #18
    Mar 2006
    Quote Originally Posted by spanners View Post
    its set on PCB3, i had the chip in there before i turned the burner on so maybe the chip dieded? also i never pressed read chip before i tryed to burn it.. where can i get a eraser from? none on ebay
  19. #19
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by RabidDog_12345 View Post
    I doubt that the chip died from that. I think it was on the willem forums I read that it might write to the chip (nothing specific) but said nothing about causing damage, and besides iv done it a few times and its still all good.
    Secondly, you dont need to read before you write. I do sometimes just to check that all the settings are correct but as long as you get a valid ID, the chip passes the blank test and the correct data you want to write is in the buffer then it should be right.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  20. #20
    VP Executive R-spec
    Jan 2005
  21. #21
    Mar 2006
    Erasable EPROM UV Lamp Ultraviolet Timer Program eraser - eBay Other Test Equipment, Test, Measurement Equipment, Electrical, Test Equipment, Business, Industrial. (end time 17-Oct-07 04:36:41 AEST)
    Everyone has these hong kong specials, you used to be able to buy them for like 1$ and then 20 bucks postage but seems the times have changed
    cheers mate, not much point buying one now i suppose, ive got erasable chips on the way by the time i get the eraser ill have my chips.
  22. #22
    Aug 2006
    some times the willem can be a dog with electric erase chips i too have a hongkong special eraser good if you dont want too unsolder eproms i just modded the eraiser to fit the memcal in whole
  23. #23
    hakhawk's Avatar
    Jan 2005
    never had a trouble with mine with erasable eproms/flash ic's. ive used plenty different ones, but surprisingly never burnt a uv erasable ic to date!!
  24. #24
    Aug 2006
    rabid dog does your burner work off usb power or a seperate power supply. the thing with the willem is its a kit it doesnt come built so it gets put together and sold by lots of different people and they use allsorts of different chips and stuff and build quality varies mine has a bad habbit of cycling the program lights every minute or 2 so you have to load the memcal in fast program and take it out fast before the lights come on and some have the read problem and i get the same thing happen same error comes up only happens to the ones i try read so i dont read anymore every read ends up corrupted any way so i dont bother wasting eproms now and mine kills chips if you put it in first obviously not all are like this but thats my willems qwirks im not the only person with cycling issues either.I have had a few memcals i got that were fried when i got them they dont program must of been zapped with static electricity by someone
  25. #25
    Mar 2006
    mine runs of USB power, i hope i dont have anymore trouble once i get my erasable chips otherwise i can see me puttin this in the (im over it) bin.
  1. VS V6 eprom chip code? 27c??
    By ragex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 08:05 AM
  2. Eprom/eeprom Erasing & Size's ?
    By ragex in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2006, 11:33 AM
  3. Eprom Emulator instead of chip
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2006, 02:41 PM
  4. DIY $20 EPROM eraser
    By pete_pumpkin in forum General Discussion
    Last Post: 22-12-2005, 09:40 PM
  5. EPROM diagnostics
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2004, 09:48 AM
