Results 1 to 9 of 9
Thread: clips in the back of cluster..
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default clips in the back of cluster..
    sorry if this has been asked a million times before but i searched and im either realy crap with the search function or its not here...
    i am currently changing to a lvl 3 cluster and i was wondering how do you take out the clips that go into the back of the cluster? i seemed to unclip them but i cant get them through the hole that is there...
    would appreciate all help, thank you
    vnss
    Jan 2005
    s.e melb
    if youre talking about seperating the switch blocks from the surround you have to undo the 8mm nut and take the alluminium bracket off.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by padrickz88 View Post
    Are you talking about the orange and blue plugs?
    and 3 Dangerous non ABS VN's
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you have to take the coloured plastic off the wire connector plugs. Then put the coloured plastic parts through the dash then then you can take the connectors through. is that what you needed to know?
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    yep thats exactly what i needed to know, but how do i take the plastic things off?
    88GreenVN's Avatar
    Jun 2006
    I used a test lamp type (looks like a screw driver) that has a point on it. That way you can get at the tags that hold the clips in place. You have to lever one side and hold it while you try the other side.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    as greenvn said. i used a small thin flathead screwdriver i've got theres clip holding them in on all 4 sides they're a pain. just lever the big one over the lip and do 1 or both small side ones then hold it like greenvn said then do the other side.
    Also when you go to put them back make sure you have the connectors facing the correct side up. i did it wrong on number 1 and had to take it off again.... PITA
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    88GreenVN's Avatar
    Jun 2006
    kool thanks alot boys ill give it a go tomorrow
    Take note of which way the plugs go back in - easy to get them mixed up and put them back up side down.
  1. Bumper Clips
    By porscheboxster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2007, 11:03 PM
  2. Radiator clips
    By jippa3000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 02:10 PM
  3. some old how a car works clips
    By yosy in forum General
    Last Post: 27-04-2006, 12:28 AM
  4. WTB: sunvisor clips for my vh
    By PEAKN6 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-12-2005, 01:05 PM
  5. wtd SUNVISOR CLIPS FOR VH
    By marinello red in forum Swap / Wanted to Buy / Trade
    Last Post: 22-12-2005, 08:28 PM
