Results 1 to 13 of 13
Thread: Thermostat
    VN Calais
    Sep 2007
    Default Thermostat
    can anyone help? VN Calais. ive removed the top heater hose into the back of the engine (mission) and cant find the thermostat, theres nothing in the hose and i can stick my finger into the block.
    am i looking in the wrong spot? is there not even one there?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    What series is it? The SI had the top radiator hose goes around the back of the intake manifold (under the throttle body), You need to remove the throttle body in order to remove the thermostat elbow peice (1 bolt). if your replacing it you need a new o-ring. SII are much easier, its located at the motor.
    Power is measured in DECIBEL
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, it's not the hose you need to remove - it's the housing that the hose sits in. There will be two bolts on the housing flange, which go downward into the motor - you'll have to remove them. You will also need a new thermostat gasket I believe.
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    There might only be one bolt on the series one, I'm too lazy to go outside and check
    VN Calais
    Sep 2007
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by greenfoam View Post
    yep 1 bolt,
    joshovn. remove the intake tube, throttle body (2 bolts?) and associated hoses etc, throttle cable, enough the move it out of the way. Then you can get to the bolt on the thermostat housing. You need a new o-ring when replacing it. have fun
    VN Calais
    Sep 2007
    VN Calais
    Sep 2007
    ### i took the throtle and ****e that was in the way out undid the 1 thermostat bolt but the #### wont ###in cum off anyone got any idears, hints, tips, trade secrets they whould like to share??????? :BANG:
    May 2004
    VN Calais
    Sep 2007
    Quote Originally Posted by dodgy View Post
    watch your language mate, you will not get my help if you talk like that
    there the only words that come to mind when i think vn, sorry to offend you but why dose it? not being a smart ass just wanna know?
    i got the thermostat out put it all back together (got pics) they to start it and it just clicks what have i knoked loose?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by joshovn View Post
    yes they can be a pain to remove those housings so your saying it just clicks now when you try turn it over? sounds like a dead battery to me.
    VN Calais
    Sep 2007
    battery is fine, when starter mortor is unpluged it makes a little click, pluged in a big click but no constant d d d d d starting sound
    VN Calais
    Sep 2007
    all fixed, forced the drive belt round a couple of times
  1. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  2. thermostat
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 01:14 AM
  3. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
  4. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 10:48 PM
  5. thermostat
    By danz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 08:52 PM
