Results 1 to 13 of 13
Thread: drove with no oil...how stuffed am i?
    VN calais 91
    Aug 2005
    Default drove with no oil...how stuffed am i?
    as some of you know, i cracked the sump on saturday night.
    front wheels dropped in ditch, manhole cover smacked sump, crack. drove about 20 metres to a parking spot where it stayed, bleeding
    2 hours later, towie comes, says "drive her onto the truck, she'll be right"
    so drove about 5 m onto tow truck.
    get home, says "just drive it into mechanics garage, she'll be fine"
    so drove it 5m into garage
    car doesn't get moved from sunday to thursday.
    theres still a pool of oil, but not much.
    mech says "reverse it, it'll be right"
    so i reverse about 5 m
    when the sump comes off, theres bugger all oil left in it.
    quesiton is...HAVE I STUFFED MY ENGINE BY DRIVING WITH LITTLE TO NO OIL?
    the sumps come off but the new one has gone on arleady without being able to check it
    how can i tell if its stuffed my engine? i think the bearings are stuffed?
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    there obviously was no oil in there at all pretty much by the look of the height of the gash i would of checked the bearings when i seen that if it was me and i wouldnt of started it let alone driven it hope youre lucky enough to not have ruined it
    VP Executive R-spec
    Jan 2005
    There's disturbed people out there in the world that drain the oil in old cars and rally them around to see how long they can last without oil in the sump, they last alot longer than you would think , you might have worn some stuff a bit but it will still keep on going for a long ime I'm sure, its a easy a cheap motor to reaplce anyway so don't loose sleep or stress over it
    VN calais 91
    Aug 2005
    thanks guys
    and thank you greenfoam
    i was really worried about it, but at least now i know i can sleep easy
    if i destroy it, i'll strip it and move onto something with more grunt, like a V8 ute
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The fact that there was still oil running out of it suggests there was enough oil left in the system to keep things lubed up enough. It should be fine.
    There was a comp over here years ago called 'go til you blow' basically hammer the crap out of your car on the skid pad until it breaks something. I had an XE falcon wagon, threw a big end through the side of the block, started it up and away I went again, pop goes another one, she still fired up. The officials told me to get off because I was throwing too much oil around. Didn't win because the car still ran.
    Visit my Facebook page
    Jun 2006
    WOW hehehe mate your car will be fine but you should contact the local council about that ditch and what it did to your car as in some cases you can make them liable for the damage to your car.
    Take photos of where it happened and the damage its done to your car and contact the council and give them copies of photos & tell them you have contacted a lawyer & will be sending them the bill and see what they say.
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Not_An_Abba_Fan View Post
    That "pop" sound is an expensive sound to hear. Also that clatter sound a rod makes thrashing around the block.. Stock car racing was a heap of fun.
    and 3 Dangerous non ABS VN's
    VS Acclaim
    Jan 2007
    That depends if you were playing silly buggers or not. Also make sure you have sufficient ride height to clear the ADR laws cos they will attempt to screw you on that im sure. i think its either 10 or 15 cm from the lowest part of the car...
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Quote Originally Posted by Billo55 View Post
    Its 10cm clearance from the lowest point on the car.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    hehe, i saw his car last week, looks pretty sacked but not stupid low, it might clear 100mm but im not %100 sure
    bugger tho
    '97 VS Commodore + '98 E36
    Apr 2005
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Oh, you'd probably be surprised how chunky that metal actually is But half a tonne of pressure on that small area is damn hardcore for any metal to withstand. That sucks, man - but I can guarantee you that running the car for 10 seconds with no oil, will do no harm at all. Heck, when you first start your car in the morning there's just as much oil in the heads as if you had drained the sump anyway
    The 1972 HQ Kingswood
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Ride Height is measured by 'eye brow' height...ie the distance from the centre of the wheel hub to the top part of the guards.Front or rear.Is in S.A.
    Tony 308vkcalais:
  1. I test drove the new VE ute!!
    By weedo_86 in forum The Pub
    Last Post: 28-09-2007, 11:17 AM
  2. Drove The VE today
    By holdensupporter2005 in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-10-2006, 01:02 PM
  3. I drove VE Today :D
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-07-2006, 01:53 AM
  4. i stuffed up :(
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2006, 07:20 PM
  5. Need re gas or stuffed A/C?
    By bodgybro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2006, 08:16 PM
