ok guys so i have purchased an adjustable fuel regulator, now how do i mount it? lol anyone with one fitted and some picks perhaps? the guy i bought it off had it on a vr and said it just fits in place of the original. tho i dont see how? .
any help would be muchly appreciated.
Last edited by mason_luke; 21-09-2007 at 02:02 PM. Reason: didnt want to start a new thread!
Yeah that is ur regulator, there exy to replace for what they are, they are around hte 100 mark easy.
Id check to see if u have any leaks around the injectors, i would be more inlcined to think the leak is there.
Also if ur injectors arnt spraying right u will be badf eccon as its not a mist of fuel and dont ignite as good
lol which one the on on the fuel rail or behind the throttle body?
Ohh its on the fuel rail on drivers side, the other one is the fuel damper
thanks for your help calais cruising, i adjusted the thread a little as i now need to know how to fit my adjustable fuel regulator...
anyone done this?
Put up a pic of it, i mite be able to help, but by logics, all you should hae to do is remove the old regulator and hook up the new adjustable one in its place
But to get a right pressure you will have to get a guage, unless it has a guage on it to show its pressure
cheers mate yeah il post sum pics up tonight of the engine bay and the regulator. and yeah it has a gauge on it so i will be able to tell what to run it at.
ok guys so i figured out how to fit the adjustable FPR, now the gauge thats mounted to it will only go up to about 20 psi no matter how tight i wind it in... at the moment i just set it between 10 and 5 psi but shoudlnt i be able to adjusti t way up to like 40 psi if i wanted to?
