Results 1 to 12 of 12
Thread: what in the hellls going on with my v6
    Aug 2004
    Default what in the hellls going on with my v6
    last few days my vn v6 has been giving me the ****s,
    it started out with a very bad miss which got worse.
    iv done a compression test all good around 150
    new leads, new plugs, changed coils and dfi module, new map sensor, new fuel pump, new fuel filter, new air filter, even a brand new loom, even used jumper leads to check that the earth is all good, changed the ecu u over changed the map sensor over for a non two bar and a stock computer still no change,
    when it does run get lots of back firing out the intake and exhuast,
    its gone from running lovely to terrible for no reason its got 1/4 tank of fuel and its shell v max, the injectors are firing because i removed them to check they were, and u can smell the fuel
    iv got no idea what could be wrong at all its driving me nuts! any suggestions please!
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Aug 2004
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    harmonic balancer? sounds like the timing is way out. Might have spun the balancer.
    Aug 2004
    balancer is fine hasnt seen any high rpm or wot at all its on a base tune nothing over 40% throttle or 3000rpm and it was running very nice
    vn/vp Speedway Street Sedan
    Sep 2005
    VX Executive Wgn, VP Sedan, V6 Ride on Lawnmower
    Aug 2007
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    vnss
    Jan 2007
    wyndhamvale vic
    your cat convertor might be blocked or check the gaskets on your throttle body also check your throttle position sensor and your air idle valve on the throttle body. also might be worth checking your temp sender or the earth to your temp sender which i think also earths your coil. it sounds to be either earth/electrical or its getting a false reading from and engine sensor.
    doms3 is offline Banned
    Vz
    Sep 2007
    I had something similar years ago ,I fitted after market leads and it ran like a pig put genuine holden ones back on and ran great .
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    id check that the key way on harmonic balncer hasnt sheered of, from you saying 'when it does run get lots of back firing out the intake and exhuast' that say its firing not in time, so pull the balancer off and inspect it,
    im sure you know the balancer has to be in the right spot so the crank angle sensor is picking up the right impulses relative to the engines cycles so the spark is timed at the right moment
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Aug 2004
    yerp balancer has never been off iv never touched the short motor it came from a mates vr calais done 170 000km the balancer will be coming off tomra and a new cas sensor put in.
    as for the earth its very good iv had jumper leeds conected to everything it has a very effective earth ( negavite ) its very sure its electrical( lucky im an apprentice sparky gorhh)
    manifold gaskets are all good, and blocked exhuast seems unlikely as its not that old and was in good condition when install also being full 3" the whole way it would be pretty hard to block thanks for all ur suggestions they are all very appreciated
