Results 1 to 13 of 13
Thread: quick question
    Vp calais
    Nov 2006
    Angry quick question
    i just put a new cd player in everythings sweet all the wires are right and the thing was working but when some of the wires were bare they touched each other and caused a spark n the cd player shut off... i checked the fuse for the radio power and it was blown so i changed it using the right fuse n tried again but it doesnt work now.... would i of buggered the actual cd player or is it something else\
    ta
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    did u check the other fuses in the engine bay or under the steering wheel, if ther fine then i got no idea :P u probli hav ruined the cd player
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i would say you have blown more than the CD player fuse,check the other fuses, i doubt the CD player is stuffed
    We got rep back, yaaay!
    VU II
    Aug 2007
    Bundy
    Also remember to check the fuse on the cd player itself. it sounds like that may hvae blown.
    good luck
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by sakid View Post
    good luck
    thats what i was going to say lol
    yeh either the fuse on the cd player and/or under the steering wheel has blown...........however im not too sure if there is aa fuse in the engine bay for the radio (pretty sure theres not)
    but sometimes (only sometimes) people that owned the car before u may have don some DIY wireing and may have wired it up to another fuse aswell as the radio one so just quickly check them all just too be safe:
    cheers
    Vp calais
    Nov 2006
    yeah the bloke before me was a hack n did the dodgey on everything!!!
    ive checked the fuse on the cd player thats all fine
    and every fuse under the steering wheel is fine aswell starting to **** me off having to leave my car at home for mums 4wheel drive!!
    Vp calais
    Nov 2006
    everything been checked and seems to be fine except the thing doesnt turn on
    VP 5L Calais
    Mar 2007
    S.A
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hmm not too sure about this but maybe there is also a fuse "insid" the cd player its self (i know theres one at the back of i)...........hopefully u havent shrted the cd player out but yeh the fuse should have blown befor that happens (should lol)
    Vp calais
    Nov 2006
    yeah hopefully lol.... i keep plugging it in n just hoping that it turns on lol but each time i get my hopes up i get crushed again when it doesnt work lol
    spose ill just have to take just the cd player to tonkins or a car audio place n see what they have to say...
    so much for a cheap diy job thats gone to the ****ta
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    i did the same thing in my VN but i got a calais with an electric arial, and it so happened that when i blew that fuse it stopped the radio working even tho the radio fuse was ok. i replaced the arial fuse and it was fine once again
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    to test if the cd player is toast or not, just connect it directly to your battery or a spare one if u have 1 handy. just get the constant 12v wire and the acc wire onto the positive terminal and the ground onto the negative and see if it powers up. if it doesn't you have blown the main IC fuse inside the headunit which means its toast and may or may not get fixed under warranty(if u have warranty and how old it is depends on that). i've had this happen to me before with my very first headunit install.
    VU II
    Aug 2007
    Bundy
    or get a multimeter and see if theres power to the back of the headunit and the fuse holder.
    basically see if u can find out how far the power gets
  1. Quick Question
    By vt_ss_5l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2007, 12:13 PM
  2. quick question
    By pgen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2007, 02:52 PM
  3. quick question...
    By jolly_97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2006, 09:20 PM
  4. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
  5. Quick question
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 04:38 PM
