Results 1 to 8 of 8
Thread: got my chips, now to burn it
    Mar 2006
    Default got my chips, now to burn it
    well ive got my AT29c256 chips, ive got the jumpers set correctly.. got the dip switchs set, if i do GET ID it gives me the chip name, if i do a blank check the chip is not emty, so then i press ERASE and the thing counts to 60 seconds, and the progress bar goes to 100%, but then it says Erase Chip Fail (time Out). when i choose this chip. i get an information bar come up and say.
    PCB3/A/B/ setting jumper
    Willem PCB Short ZIF32 PIN3 < - > PIN31
    does this have anything to do with it? its really annoying me now i was gettin ready to start testing some chips but i cant even erase the chip to burn something.
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    you have too put a wire in the zif with the eeprom you need too put it between pin 3 and pin 31 some of the willems didnt have the jumper so you have to do it manually with a bit of wire if you have the wrong willem
    Mar 2006
    VP Executive R-spec
    Jan 2005
    Don't you have the 28 pin atmels? if you do you don't need to erase them (gives a error like you say) they just erase when you burn them so it's pointless anyway, just hit burnnnnnnn
    Aug 2006
    VP Executive R-spec
    Jan 2005
    Aug 2006
    Mar 2006
    thanks guys... as spanner said.. it worked and im as happy as a pig in ****
  1. LCD Image Burn-In?
    By azzfox in forum Car Audio
    Last Post: 26-11-2007, 05:27 PM
  2. VS will not do a burn out
    By sassy_41 in forum Just Commodores Polls
    Last Post: 20-08-2006, 08:20 PM
  3. Peformance Chips?? Sport Chips?
    By jeffarido in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2005, 08:12 PM
  4. Red and green, next episode..Burn BAby Burn
    By The1985divo in forum Jokes/Humour
    Last Post: 08-08-2004, 09:01 PM
