Results 1 to 16 of 16
Thread: Noisy Lifters
    VN Wagon
    Feb 2005
    Default Noisy Lifters
    The lifters are starting to sound noisy with that ticking sound coming from the valley of the V6. I see people have used either an engine flush or lifter free.
    Do these products work? Particularly Nulon Lifter Free? Any bad side effects?
    VN Wagon
    Feb 2005
    UPDATE
    Tried a bottle ($12) and after a week it has quietened it down but has not gone away completely. Mind you I don't think it was ever 100% quiet.
    VT Berlina & mazda 2 DE
    Jul 2006
    I have found as well as others PM Lubes oil works well, as typically people use a slightly thicker oil (25w60) which helps, but the oil is very detergent, so it cleans the carbon from passages, just as the lifter free additive does.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by bradcad View Post
    25W60 oil is good stuff
    as for the lifters i too had a real bad TICKING nois so i put a bottle of whnns engine tuen up stuff in it and it has quieten down ALOT since then
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    there have been issues with rattly tappets being caused by blocked pickups in the sump of the vn's too .heres a pic.
    Jul 2006
    VN Wagon
    Feb 2005
    Gee with "Lifter Free" in the engine and "Bar's Leak" in the radiator, all I need is some "Suspension Tuneup" and "Headlight Fluid" and "New Car Smell" in a bottle to complete the VN upgrade.
    Jul 2006
    VT Executive S2
    Sep 2007
    Thumbs up Noisey lifters
    Try a product called Pro-Ma MBL8, this stuff is ausome it will get rid of any noise in your engine. A bit pricey at $30Aus for 250mls but you only need to use around 15-20mls per service and it really does work!!
    Just Google Pro-Ma MBL8 and you will find how to score some you wont find this stuff in Repco or Supercheap etc.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by oranjboots View Post
    That **** is just moly lube and some form of thinner so it's miscable with engine oil. Said it before and I'll say it again, if your lifters are getting noisy, then they're getting close to needing replacing or reconditioning. You V6 boys have no excuse anyway, you can just chuck in new lifters without worrying about chewing lobes.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    VT Executive S2
    Sep 2007
    This so called **** is not suppose to be a permanent fix, it doesn't take a rocket scientist to know that if it's broke fix it. No amount of lubricant will fix it and depending on how noisey the lifters are this product will reduce the noise!!
    Jul 2006
    Sometimes its just not worth pulling things out just to fix a noise if a simple oil change helps enough
    xlr8_87's Avatar
    xlr8_87 is offline No longer a commy driver
    '96 Prado 4x4
    Mar 2006
    Melb, VIC
    do what i did, replace the engine with an ecotec
    mind you i had a suspected conrod bearing going too...
    <<<Rob>>>
    Ecotec VP, 135rwkw, 427nm
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    how much are lifters and are they hard to change?
    can i do it?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  15. #15
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by azkwazere View Post
    can i do it?
    aZk.
    i was quoted 21 bucks each for me vn v6........but i think the v8 ones are cheaper............dunno how hard it is as i never done it befor but may be doing it in the near future
  16. #16
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by jas98 View Post
    Sounds a bit on the expensive side. The V8 ones are significantly cheaper as they are flat tappet, but even for the roller V6 lifters, $21 a pop is a bit harsh. Shop around I'd say.
    There is a tightarse option if they're just a little noisy. Taking them apart and giving them a clean in solvent might help. Put em back together, check that the plunger motion is smooth, bearing motion is smooth, soak em in oil for a few hours then chuck em back in. Started doing this with my V8 last summer, then I decided that they were pretty much cactus so I went a bit crazy with the expenditure. Anyway I ramble too much.
    Azk, replacing them isn't hard, but really I'd only do them if they really needed replacing or cleaning. You have to remove the inlet manifold, the rocker covers, rockers and pushrods. Then the lifters just lift out, possibly with the assistance of some needle nosed pliers.
  1. Noisy Lifters?
    By Macca177 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2007, 04:30 PM
  2. Noisy Lifters
    By Tarsius in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2007, 04:11 PM
  3. noisy lifters? maybe
    By sleepyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2005, 11:58 AM
  4. Noisy Lifters
    By Boonie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-11-2005, 08:09 PM
  5. Noisy lifters
    By Inch in forum LSx Development and Modification
    Last Post: 12-05-2005, 05:20 PM
