Results 1 to 12 of 12
Thread: Torque converter dosent fit into manual crank
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Default Torque converter dosent fit into manual crank
    Both series 2 engines but the troque converter shaft is to big to fit into the crankshaft.
    And yes i am converting from manual to auto because i converted my auto to manual and want to get the donor car doing burnouts.
    Any help you be appreciated.
    Thanks, Jonathan
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    if there both series two, they will both fit, both v6?
    your doing something wrong...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    yip both v6 and the flex plate is the right way around. im pretty sure it slide into the crank shaft on the other car, but dosent fit into the crank on the donor car, and they are both the same engines
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    remove the brass bush (spigot bush) and it will fit you may need to smash it out if its tight
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Is it only S1 engines that differ between the manual and Auto? When I changed my VN from Manual to Auto (S1) I was told I had to change the motor at the same time as the crank is not the same.
    and 3 Dangerous non ABS VN's
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    thanks, oh F*** was that spigot bush spose to go in my auto to manual conversion? does it really matter?
    vq rat's Avatar
    Mar 2006
    hamilton vic
    are yer it comes in handy it stops the input shaft flopping around, there are only a few $ from holden they are really a one use only as they damage easy on removal
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    May 2005
    .....SE Burbs
    Important, think there about $10....
    Glad you sorted it out though...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Got me a new spigot bush
    My gearbox is almost out again, just having a break at the moment
    and got the spigot bush out of the other car and torque converter and flex plate are on now
    and without the spigot bush in my car my clutch will blow up in no time as well, glad i found out about the spigot bush though even though I am a bit annoyed i gotta take the gearbox out again
    Thanks to you guys anyway, youve saved me a bit of money if my clutch or gearbox went
    Aug 2006
    lucky you hadnt been out for a drive aye
  1. torque converter
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2006, 10:53 PM
  2. Torque converter?
    By spauldj308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 07:02 PM
  3. Torque Converter
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 03:52 AM
  4. Torque converter on VS
    By Gleno in forum General
    Last Post: 31-05-2005, 01:13 AM
  5. Torque Converter
    By vrmusicman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 08:47 PM
