Results 1 to 3 of 3
Thread: vr rear seal into a vn
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default vr rear seat into a vn
    Just wondered if anyone has put a back rear seat out of a vr in their vn because I tried to do it and I realise that I have to drill 4 holes to mount the centre pull down seat bracket to the floorpan but the metal it sits against isnt flat...do you have to space it away with washers etc from the floor pan to get it to work?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    PM airstrike, he fitted a VT seat with the same issue, pretty sure he just drilled them in.
    The VP's luckly enough came with the holes already!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Nov 2003
    northside brisbane
    Checked out a car at the wreckers and the floor pans have gussets in them on vns where you have to drill it ...a vr/s has that part flat but Is'pose that is only a bit of gentle tapping.
    Another thing I found out....the bracket bolted with the u piece that the centre seat strikes against at the top is exactly the same as reinforcing bracket that the seat hinges screw to that is welded to the pan ....right down to the distance between holes and captured nuts....get 2 from the wreckers and cut off the u piece and it will fit perfectly after you drill the holes for the hinge bolts in the floor.
  1. Rear Main Seal
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 10:01 PM
  2. Rear main seal in VN 5lt
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 08:46 PM
  3. What rear main seal to use in hot 253
    By Mattie77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2005, 05:20 PM
  4. VR Rear main seal
    By Ute 94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 09:47 PM
  5. rear main seal
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2005, 02:38 AM
