Results 1 to 5 of 5
Thread: How to replace the air compressor pully bearing
    VN S2 V6 Berlina
    Apr 2007
    Default How to replace the air compressor pully bearing
    Any advice as to replacing the pulley bearing on my VN S2 V6. The air was just regassed and the compressor sounds/feels rough (from the drivers seat)from about 2500rpm up. Only noisy when compressor clutch in. It's quiet at idle when compressor clutch in.
    Thanks
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    did they refill it with oil when they replaced the gas they took out??? cos the oil and gas mix together and gets drawn out when the system is being evacuated.... and when its not refilled with oil the compressor gets noisy
    VN S2 V6 Berlina
    Apr 2007
    I don't know. It was done at a long term Air specialist. I have to asume that he knew what he was doing. But I will take it back to him for a diagnosis.
    kirkson is offline Captain
    93 vr v6 exec duel fuel
    Oct 2005
    Oct 2005
    Hi Peanuts, I recently had the same problem, noisy clutch bearing on aircomp I used to give it a squirt with wd40 this shut it up for a while but inevitably I had to have it fixed, I found that I could not buy a new clutch anywhere so I grabed one from the wreck yard easy enough to change remove belts undo outer nut remove washer / spacer and gently ease the clutch from the shaft, do not pry it off with a screwdriver you may damage wires behind pully, use a pully tool if u have one. anyway I did fix mine this way but it only lasted 3 months so I eventually had a new compressor etc etc fitted total cost $930.00 but all is good now. regards kirk
    Captain
  1. VN compressor bearing
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2006, 08:08 PM
  2. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  3. how to replace tail shaft bearing
    By crouchy69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 05:39 PM
  4. Strut bearing, how to replace it?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2006, 11:13 AM
  5. How do you replace the distributor bearing?
    By Holdfast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2005, 08:39 PM
