Results 1 to 11 of 11
Thread: DIY earth kit?
    vnss
    Jan 2007
    wyndhamvale vic
    Default DIY earth kit?
    has anyone made an earth kit for their car, if so how and where have you put your earth points. very interested.. thanks
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    4awg Wire...
    Battery terminal negative, back of driver side head, back of passenger side head, passenger strut top, front of passenger side head, alternator bolt, then back to battery terminal, improved idle & got rid of headlight dim.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vnss
    Jan 2007
    wyndhamvale vic
    thanks hozy, sorry mate,silly question but did you use one length of wire or did u cut them into lengths and go from bat.neg to d/s head then to p/s head then to p/s strut and so on?
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    cut them into measured lengthes then terminate them & use bolts...
    MaT
    vnss
    Jan 2007
    wyndhamvale vic
    Jun 2005
    if you want cheap wire, like $3 a metre, go to dick smith
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hey guys was reading this and was wondering would it be wise if i did this?? car idles ok and goes ok but would it beee good to do??
    cheers
    VP Executive R-spec
    Jan 2005
    It's on my list of things to do to the VP in the comming weeks as it barely turns over with the headlights on :P
    1989 VN Series I
    Apr 2005
    Would this help get rid of static electricity as we get massive shocks when we get out of the car?
    We have an earth strap, softener on the seats each month and don't wear polyester clothes...
    One other point to earth.. Is the radiator to the negative battery terminal. To stop VN's chomping through water pumps, aluminium radiators and anything else alloy...
    Steve
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    have seen this done on a ricer with before and after dyno runs, it made a little more torque although lost a little peak power funily enough. earthing systems are one of the places that the factory wiring has always been a letdown, especially on the earlier model commodores. i used 35mm2 welding flex to earth the 2 heads and battery + chassis. also used it for the starter motor feed and alt to battery feed also. no voltage drop there now
    Body by Holden, Soul by Brock
    the Legend will live forever
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    I have added an extra 16mm2 earth to the body and to the engine cant say if it helped or not but it sure beats it trying to earth through something pricey like the ecu
  1. vk - bad earth???
    By 308commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-04-2007, 09:35 PM
  2. Bad Earth????
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2007, 11:06 AM
  3. Why is the earth so hot?
    By ECILOPX in forum Electrical Wiring / Questions
    Last Post: 05-04-2006, 12:56 AM
  4. vs earth
    By jds303 in forum Car Audio
    Last Post: 31-03-2006, 07:30 PM
  5. hot earth?
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2006, 10:47 AM
