Results 1 to 10 of 10
Thread: idling rough
    holden
    Sep 2007
    Default idling rough
    hello can i ask something else, can you give me a list ranging from cheapest to the dearest of what causes my vp v6 to idle a little rough. please include rough secondhand and new prices on parts so i can compare and where is the tps, mas sensor located
    Mar 2006
    rough idle can be caused by a vacum leak.. i had a really bad vacum leak aroun the injectors, replaced the o-rings and its been sweet ever since... you can turn the hose on and run it around all the manifold and vacum joints.. it the car seems like it wants to stall then its most likely sucking the water in /
    holden
    Sep 2007
    wheres the tps and mas sensors located and can you give me lists on what causes rough idle ranging from cheapest to most expensive and list rough new and secondhand prices
    VN Wagon
    Feb 2005
    Depends on what you mean by rough? These V6 engines aren't sewing machine smooth at idle.
    Is it missing? Can you hear a pop or cough at the exhaust tip?
    Is it idling at the right idle speed?
    Things I have seen cause the idle to be rougher than normal;
    Bad spark plug lead (causing a miss)
    Bad spark plug (causing a miss)
    ECU getting scrambled (causing low idle, needing a full reset)
    Faulty or jammed idle control valve (causes low idle speed)
    Low fuel pressure
    I would agree with Rabid on vacuum leaks or TPS issues.
    I'm sure others can add more causes.
    TPS is attached to the throttle body. MAS (you mean MAP?) is on the passenger side firewall.
    holden
    Sep 2007
    ill tell you what when you are sitting in the car sometimes it feels like its rattling abit while idling but its not loosing power and doesnt pop and does sound healthy other than that so is that rattle feel normal
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    ok, first you say idling rough, now you say its rattling? what is it? a rattle or rough idle? maybe your tensioner pulley bearings stuffed and is making it rattle
    holden
    Sep 2007
    its hard to tell the pulleys been replaced it only feels like its vibrating/rattling when sitting inside but it doesnt loose power other than that
    hakhawk's Avatar
    Jan 2005
    vn calais, vs clubsport #137
    Jun 2005
    bita crap in the throttle body, vaccum leak, low fuel pressure, dodgey lead, dodgey spark plug, dodgey coilpack.
    try resseting the idle valve
    i think you hold the rpm on 2000 for 20 secs. see what is like after that.
    Jun 2005
    has the belmouth been removed from the motor? if so. expect a rough idle lol. these things were not the best idling thing since sliced bread to begin with lol.
  1. rough idling 5 litre
    By ringfeder3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 09:38 PM
  2. vs idling rough
    By fang in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2005, 10:48 PM
  3. VR rough idling
    By jimmy80 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2005, 11:27 PM
  4. Rough Idling
    By VT TOMMY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2005, 09:24 PM
  5. idling rough
    By ken & hank in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-07-2005, 10:30 PM
