Results 1 to 7 of 7
Thread: Temp gauge red hot / engine NOT overheating??
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default Temp gauge red hot / engine NOT overheating??
    Hey guys, yesterday i was driving home from work at 3pm, and i noticed my temp gauge was above three quarters! my car has never ever gone above a quarter since i have had her, so i pulled over lifted the bonnet...... all was fine, wasnt hotter than usual, check the water level that was fine, so i kept driving yet it continued to climb up to red hot, car felt fine to drive too! Got home let it sit for a few hours then went back out to check for any leaking water. Nothing. The ground was bone dry. It only seems to get red hot when i'm accelerating, but when i'm stationary at lights etc, it drops down to normal then i take off and it climbs again. The fans are all working i can hear them kick in when i leave it idle for a while.
    Is there a chance the wire for the gauge has come loose and is shorting itself out and making the gauge go all weird?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    i just dont think its so easy to say its not overheating.... you need to be more certain as visual checks wont do... id be concerned about your thermostat as it may have ceased leaving only one side of the engine overheating and not the other....
    would adversly affect the temp gauge too
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Thermostat eyy? That's the first thing my mechanic mentioned. Maybe we should give that a try first?
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    I wouldn't imagine there would be ALOT of things that would make the temp gauge react like that if i'm not losing any water...?
    May 2005
    .....SE Burbs
    for a part that costs $20 and can be done in about an hour including coolant flush time, its a good place to start, thermos cause alot of issues when not working:
    over heating
    Thermo Fan failure
    Unbalanced cooling
    have a look-sy
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    All good just picked up a new thermo and gasket from holden
    $15 can't go wrong, this will be the second cooling system flush in less than 2 months as we did the radiator and coolant sensor a month and a bit ago and gave it a flush then
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Sorted
    The themostat was jammed good and tight so we took a sledge hammer, put the old thermostat on the ground and smashed it until we couldn't smash it no more!
    Put the new one in, temp gauge is perfect sits below the 3rd notch on a level 2 cluster.
    Very nice i like high five!
  1. vl temp gauge
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2006, 11:22 PM
  2. Temp Gauge
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:26 PM
  3. vn v8 overheating when at operating temp??
    By misslisa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2006, 09:22 PM
  4. Temp gauge or fan?
    By The1985divo in forum General
    Last Post: 08-08-2005, 10:18 AM
  5. temp gauge
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-08-2005, 09:54 PM
