hi, guys, I found one of the hoses from the radiator( supposed to be the transmission fluid inside) is leaking at the end from the radiator. the hose is being harder, and I tried to fastenit but does not seem to work. could I change it myslef, my idea is loose the clamps and try to block each end with something. is there a high pressure? if yes, I have to give up and let the mechanics ripped off.
Its high pressure when the motor is running mine is doing the same and i got to change it soon. It's going to leak out a bit of fluid and if your replacing it you'll need at least a high pressure rated hose and maybe some fluid to replace whatever lost.
Might be worth getting a tray to catch the fluid draining out the raidiator
Easy fix. Leave the motor off for a while and rip it off and replace it. I think 5/16 fuel line will do the trick. should get bugger all fluid coming out as most of it will drain back into the box. If you don't wanna dirty up your garage floor, you might wanna catch it though. The important bit is to make sure you don't let too much dust and dirt get into the ends while they're open. Have fun.![]()
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
