Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Strong Petrol smell in my Vn
  1. #26
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    pete that small black hose i had a look at 2day how does that go 2gether exactly it looks like the rubber hose fits inside that slightly larger small rubber hose ur talkin bout lol? y is it like that? can i not just connect it up 2 the metal pipe on the other end?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  2. #27
    VN Wagon
    Feb 2005
    Hi,
    Decided to pull that part of the car apart and get you some pictures. Would have been sooner but Sydney is half underwater today!
    Anyway.
    Shows the canister and top of the fuel filler.
    Shows the bottom of the canister.
    Shows the lines as they pass near the fuel tank.
    Hose #1 starts out near the top of the filler pipe. It is a small hose but then is joined to another short larger hose (You can just see it at the edge of the picture "Fuel Tank 3A.jpg"). This then goes into a hard fuel line.
    Hoses #2 and #3 start at the bottom of the canister and run to the top of the tank.
    Hard Hose runs from the top of the filler pipe and runs near the filler pipe as it enters the fuel tank.
    Note that there are also two hoses from the top of the filler pipe to the top of the canister. These need to be replaced as well.
    Also note that the hose clamps and some of the hoses in the picture are not the standard ones and that the standard hose is sort of clear and smaller in outside diameter. The wet patches aren't fuel but due to the drenching the car got today!
    Hope this helps.
    Pete
    Attached Thumbnails Attached Thumbnails Strong Petrol smell in my Vn-fuel-tank1a.jpg   Strong Petrol smell in my Vn-fuel-tank2a.jpg   Strong Petrol smell in my Vn-fuel-tank3a.jpg
  3. #28
    VN Wagon
    Feb 2005
  4. #29
    wrx884's Avatar
    Mar 2006
    thanx 4 goin 2 so much effort 4 that pete now hose #1 in ur pics did u change the smaller hose that starts at the top of the filler pipe that then fits into that smaller larger hose thats at the other end of that hose? basiclly i wanna know how that hose is attached 2 the smaller diameter hose? has it just been pushed inside the smaller hose?
  5. #30
    VN Wagon
    Feb 2005
    Quote Originally Posted by wrx884 View Post
    hmmm............good question.
    Because I changed these over a number of years starting with the easy ones at the top I can't remember whether I changed hose #1. I vaguely remember that I did get the right size hose the first time I changed these.
    Personally if you have the right size hose then I would change it.
  6. #31
    VR Acclaim
    Dec 2007
    Cut the 17mm OD black hose before you lower the tank, I paid $9 at the local holden dealer,replace the wire clips with small clamps, it's much easier
  1. Petrol like smell in cabin
    By Marzz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2007, 05:54 PM
  2. 5.0 on LPG with very strong petrol smell
    By VS Callahan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 01:57 PM
  3. Petrol smell in car
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 01:19 PM
  4. Strong fuel smell from engine bay.
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-04-2006, 09:58 PM
  5. Got regased today - strong smell of ? inside car
    By holden_nutt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2006, 12:07 AM
