Results 1 to 10 of 10
Thread: Weird clunking noise from front of car
    CLE
    CLE is offline
    Mar 2005
    Question Weird clunking noise from front of car
    Hey,
    I've been having trouble for a while now with my VP Berlina.
    There's this loud clunking noise coming from the front right of my car (somewhere near the wheel). It happens whenever there are bumps on the road, no matter how small they are and it happens on any surface.
    I can also feel it through the steering wheel.
    And for some reason it only starts making noises after I have driven it for 50-60 minutes..... before then it's as if the problem doesn't exist.
    Any ideas??????
    Thanks!
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    Hmmm ****ed struts/shockies, loose boody panels, power steering rack somehow ****ed, loose strut, ****ed balljoint????
    I FRYED RICE!!!
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    link pin bushes are non existant.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, a shagged swaybar link pin will do that. Check the vertical pin linking your swaybar to your strut. There should be a large round bush on the bottom and top of each end of the link. If not, it's replacement time
    The 1972 HQ Kingswood
    redcedar's Avatar
    redcedar is offline workaholic
    Alto Grey MY12 SS
    Nov 2005
    coffs harbour
    link pin bushes are a pain to do on your own.So find a friend to help.(i found out the hard way)
    Morton's Avatar
    May 2006
    Yeah, you gotta jack the car up by the K-Frame, support it on stands, then use your jack to put pressure on the correct wheel to relieve the swaybar tension. Damn pain.
    VP Executive R-spec
    Jan 2005
    Common guys don't you own a crowbar:P ram it under the kframe and push hard on the sway bar :P
    VT Series 2 Exective 2000 V6
    Oct 2010
    Pakenham Victora
    i have had the similar problem. i have a VT commodore.
    every time i push and release the brake, there is a clunk noise from the front left of the wheel bay, the clunk is also when i go over a bump. i have changed the the sway bar links and bushes. i have replaced the the bearing hubs. and now the noise is still there. i know i need a wheel alighment, but i dont know if there would more bushes that may be making the noise and need replacing.
    thanks
    VP Commodore SS 1992
    May 2011
    Auckland NZ
    My commodore used to clunk over bumps in the front prior to replacing the caster rod bushes. now no clunking over sleeping police men !!!
    D22 St-r Navara
    Dec 2010
    perth
    had the similar problem, had new bushes front and rear, pedders checked it and said half my brand new bushes were worn out, lol but the clunking was still there. ended up being a loose strut insert collar on the drivers side
LinkBacks (?)
  1. 17-08-2011, 07:08 PM
  1. weird pulley noise coming from front of engine
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 12:37 PM
  2. clunking noise from under the dash
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2006, 08:10 AM
  3. vt clubsport clunking noise
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2006, 03:11 PM
  4. Front Brakes - Weird Noise when Breaking
    By B3NKobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2006, 04:15 PM
  5. Clunking Noise
    By blade_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:57 AM
