Results 1 to 9 of 9
Thread: changing diff oil
    vn executives
    Sep 2005
    Default changing diff oil
    hi, guys, how often do you change diff oil, I am curious how difficult it will be, just changed engine oil, want to have more fun.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Ahhhh you can change it if you like. Replace it with some good penrite oil. The stuff doesn't need to be changed that often for a standard diff really. If you've got a good LSD that you drive hard, I'd perhaps suggest replacing the oil every 30,000.
    You can do it once a year if you want. Helps keep things fresh, and it's not expensive
    The 1972 HQ Kingswood
    vn executives
    Sep 2005
    Quote Originally Posted by Morton View Post
    I got a very loud noise in the back of the car some times, is it the diff or the petrol pump? if it is the diff I will definitely change it. where is the drain plug for the thing?
    Morton's Avatar
    May 2006
    Plug = the thing on the back plate made of rubber that you can prise off with a screwdriver. Try everything - it won't take you long to find the rubber
    Oh, and it's not a drain plug - it's a filler plug. You drain the diff fluid through the bottom bolt of the cover plate. Remove the bolt. and let the fluid drain through it. Then, once empty, fill the diff through the rubber filler plug until it is level with the plug (assuming the car is level and not jacked up), then close it up and you're done!
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    vn executives
    Sep 2005
    many thanks, mine got 192000km but did not know if the previous owner did it or not( 158000km when I got it).
    VN Exec V6S1 man
    Aug 2007
    Adelaide SA
    I changed mine on the weekend depending on how full of crap and how long since it was last changed it may not just leak out the bottom bolt. when i changed mine i had all the bolts out and there was no oil coming out n e where. you may need a new gasket if you have to break the seal, i personaly prefer to take the housing off therefore you get all of the crap and metal shavings out and you get to see if there is n e damage.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by *VN88* View Post
    that's cause the s1 diff housing doesn't have the drain hole throught the bottom bolt. mine doesn't either. first time i did mine, i removed cover, drained oil, then squirted fresh oil through the diff center to flush all the crap out. then refitted cover and filled with good oil. definitly spend a little extra on the oil if it's LSD. once done, maybe do the diff oild when the transmission (mines a manual so gets done more often) otherwise do it every second engine oil change. do LSD diffs more often then a standard open diff, the LSD cones are wearing parts and contaminate the oil. clean oil will help it live longer
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN Exec V6S1 man
    Aug 2007
    Adelaide SA
    Thanks for the info man!!! learn something new everyday!!! the good old gregory's didnt state that the series 2 had a drain hole.
  1. Changing diff oil ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:01 PM
  2. changing diff centers
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2006, 03:13 PM
  3. changing diff
    By meanrooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:52 PM
  4. changing diff oil on VS, how much?
    By pHiLix in forum General
    Last Post: 31-05-2005, 07:57 AM
  5. changing diff oil on VS
    By pHiLix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2005, 08:45 AM
