Results 1 to 19 of 19
Thread: oil volume
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default oil volume
    hi, can someone have a look in their gregories for me and let me know how much oil a 3.8L takes with filter?
    cheers
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    4.1 with filter, 3.8 without filter (VP gregorys)
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I usually get about 3.5 in with filter change. Better I find to be a little under full, than a little over.
    The 1972 HQ Kingswood
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    I usally put in about 3.8litres with filter change. i think 4.1 would be way too much unless you can drain every drop out of the engine and sump. Just put 3.5 in at 1st and check it, and keep topping it up till its right.
    Australia. Love it or leave it
    vn calais, vs clubsport #137
    Jun 2005
    Jun 2005
    stop when you can look into your filler and can not see your rockers anymore. that is a good level......... lol..
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by vk calais manual View Post
    really??? (goes add oil).......jks
    haha
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    reason i ask is i have a custom sump that somehow doesnt have a dipstick....
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by VTPREDATOR View Post
    thats a risky proposition. i'm guessing maybe you have a later model alloy sump fitted??? really should have a dipstick fitted, it's the only safe way to check the oil level. i'd imagine you check it on a regular basis between oil changes i hope
    Body by Holden, Soul by Brock
    the Legend will live forever
    Morton's Avatar
    May 2006
    Nah, it's easy enough to check levels on a stickless sump.
    1) Put roughly 3.5 litres into your engine, and allow 10min to drain to the bottom.
    2) Drain the sump into a measured bottle.
    3) If you find 3.5 litres in your bottle, you had exactly 3.5 litres in the engine.
    4) Plug sump and place oil back into engine.
    O_o duh? lol
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    sorry to hijack ur thread.. but what happens if u put too much oil... cause im a fair bit over the full line.. its been like that for about a month now?? but will b doin a service in a few weeks..
    cheerz
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by dijm8 View Post
    cheerz
    lol mines abit over full..............but then again it will leak it out in a few days lol (dam sump gasket) fixing soon
    but yeh i dont see much wrong if its a little over but not a heap over.
    Morton's Avatar
    May 2006
    if you're a fair way over full, you can start to get oil slapping around and sometimes getting into your pistons and burning. But generally it's not a HUGE issue. As a general rule though, you're better off with a little less, than a little more. I ran my old 626 with less than half oil for 6mths and it kept going I looked after that car SOOOOO well. ... >_>
  15. #15
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Morton View Post
    O_o duh? lol
    sounds like way to much work to check the oil level when a dipstick does it in about 10sec flat.... and with a coldy in the other hand too
    cheerz
    if theres to much oil it will get caught i nthe crank causing windage losses. not that you will notice in a standard street driven car. it's the reason they spend sooo much time designing/developing windage trays/crank scrapers for race cars. on high output engines you can loose a fair few HP due to windage losses nad it gets worse with higher RPM's also
  16. #16
    Morton's Avatar
    May 2006
    Quote Originally Posted by immortality View Post
    You KNOW I was taking the pish, right?
    haha, sif drain everything you just put in, to check how much you just put in...
  17. #17
    vn executives
    Sep 2005
    hi, the engine oil should be checked when it is hot, warm or cold? I got different answers fromt he internet.
  18. #18
    jolly_97's Avatar
    jolly_97 is offline THE VACATIONER!
    1992 VP Vacationer
    Mar 2006
    Port Lincoln
    on ure dipstick theres a full line, then another line that says 'full hot' so either way u will get a pretty decent reading...
    Quote Originally Posted by Stevob
    I check my oil every 3 minutes...just to be sure.
    HEY RICE BOY! I GOT TORQUE, U GOT TALK!
    my ride- http://forums.justcommodores.com.au/...ad.php?t=29425 newest pics last page...
    THE VACATIONER LIVES
  19. #19
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    That would be the transmission dipstick, the engine oil dipstick just has Add and Full. It should be checked cold and on level ground. Leaving it overnight before checking is the best scenario as any oil in the rest of the engine will have had plenty of time to drain back into the sump. The VT manual says 4.5lt and 300ml for the filter.
    Visit my Facebook page
  1. maximum volume is crap...
    By ~shellee~ in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2011, 01:28 PM
  2. Anyone seen new radios with volume on right side?
    By holdenrules in forum Car Audio
    Last Post: 18-04-2007, 12:05 PM
  3. Box Volume Calculations
    By shaggerz in forum Car Audio
    Last Post: 29-03-2007, 04:05 PM
  4. Gday and oil volume
    By wethepeople in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2006, 07:14 PM
  5. Audio Volume
    By Shivaga in forum Car Audio
    Last Post: 06-10-2005, 01:56 AM
