Does anyone know does the overspeed on a vp level 3 dash have a w/l light ect as well as the chimes.
Phillip![]()
Yes it does mine chimes and the overspeed light comes up
Ok thanks for that
Q2 where in the panel is it ?
i looked through all the windows in the light panel and did'nt see ne thing that i thought might have been it !!!! old timers desease maybe ??????
Regards Phillip![]()
I'm not sure as i have it set to 105 and barely ever reach that but i think it's just left of the center where the reset is on a level 1 I'll check it out for you though next time i drive it. Have you done the conversion yourself? It might be that one of the wires didn't get swapped around i can't remember if it needed to be or not.
ok thanks for that,the chime works but no light so i'm a bit lost.
I did a full statesman interior conversion using the complete wiring lume.
is it a vp cluster or a vn(vq series 1)? i'm not sure if the vn and vq series 1 had a light
EDIT: i just went and checked its actually just to the right of the center next to the temp gauge. When i turn the ignition on it briefly lights up with a few of the other lights. It also lights up yellow with a SPD in it
