Results 1 to 7 of 7
Thread: VN Temperature gauge not working
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    Default VN Temperature gauge not working
    The temperature gauge on my VN is not working. Other posts I have read indicate that the temp sender is needed to set the fuel to the engine so I can not just ignore. Not in my nature either, some people can ignore something not working right - others can not.
    Engine starts OK and the fuel economy seems OK. Does this mean it is just the gauge? Is it fed from a fuse? If it is a fuse, what else is on the same fuse that I can check to see if they are not going? Maybe a connector to watch out for? Cheers
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It would be one of three things:
    1) your water temp sender is faulty
    2) your water temp sender is unplugged
    3) your dash gauge is faulty
    First two are the easiest to check:
    Remove the left hand bolt of your anternator, and swing it up. Behind it, on your inlet manifold, are two sensors bolted in. The one on the right has two wires and is your sensor for the ECU, and the one on the left has one wire, and is your sensor for the dash gauge.
    If you want, you can replace the sensor on the left (the dash gauge sensor) for around $12. It's easy to unscrew, and you won't lose much water at all while doing the switchover. (obviously check if the sensor is plugged in first. The wire sort of slides over the top of it.)
    If this doesn't rectify your problem, then it's probably easier to try sticking on a second hand dash cluster. If that fixes it, then it's a cluster issue
    Don't worry about your fuel issue. Your ECU and your dash gauge run from different sensors, so if your dash reads nothing, the ECU probably still knows what temperature things are running at. Although if you're going to change the smaller sensor, it's probably worth changing the ECU sensor too while you're behind the alternator. Only around $15 anyway
    Hope this helps.
    The 1972 HQ Kingswood
    VN Executive
    Oct 2007
    Thanks, Morton. I was under the impression that the sensor was common. Much easier now that I know where the sensors are. I will check it out some time but now I know the temp gauge not working does not effect the engine I can wait until I get other things done.
    VP Exec
    Dec 2006
    also try this.. give the dash above it abit of a bash. works if its a sticky gauge.
    VN Executive
    Oct 2007
    Well, further down the track, now. Thought I would post an update. No, it was not sticky gauges. Took them out and checked thoroughly.
    It was not the sender unit. Replaced it with a new one. Thanks to Morton who said the sender was under the alternator. The advice was spot on. The book I read said it was at the rear of the motor on the drivers side but evidently it was changed for the 91 VN.
    Shorted the sender to ground with the ign on and the gauge goes right up to max. Measured the resistance of the sender and seems OK. So what is going on? Could it be possible the coolant (in the intake manifold) never gets hot? Maybe a blockage in the water passages? The gauge still does not read anything.
    Morton's Avatar
    May 2006
    Nah, I don't think a blockage would cause the temperature to stay down. Even if the water wasn't flowing, it would still heat up.
    Perhaps it's time for you to fit an aftermarket temp gauge? I was getting strange readings from mine, so I installed a whole new Specometer gauge just next to my dash. Works a wonder, and now I always know exactly what temp my car is running at
    I then hooked my dash gauge up to a second sender I installed outside the thermostat on the return hose. It's just basically there to make the needle still move, 'cause it would bug me if it was dead ^^
    How long do you drive your car for? Just short trips? It's possible that it will take a while for the gauge to show anything... You've got me puzzled really?! lol
    VN Executive
    Oct 2007
    Someone had taken the thermostat out. Temperature gauge was OK. Just temperature never read. Put in a new thermostat and reading normal.
  1. Temperature Gauge
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 07:49 PM
  2. temperature gauge
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 09:59 PM
  3. Temperature Gauge
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-12-2006, 10:12 PM
  4. Vt Temperature Gauge
    By stephen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 10:18 PM
  5. Engine Temperature gauge
    By HsvMan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2004, 05:18 PM
