Hey guys, sorry if this has allready been posted up i just want a quick answer. i am hooking up a tranny cooler to a VN V6 S1, and would like to know where the hoses go from radiator to tranny. thanx
You want to know which is which or where they actually are?
the hoses that hook up to it from radiator top and bottom what one is what and where do they connect to the tranny cooler
Personally, I run the cooler separate from the radiator.
I'm pretty sure the bottom one is the feed pipe and the top one is the return line. If you are using the radiator, hook the top line from the radiator to your cooler, then the return line to the cooler. The fluid has to run from the trans, through the radiator, through the cooler, then back to the trans. If you aren't using the radiator, it doesn't matter.
o is there anything you have to do with the hose on the radiator if you just run it through the cooler?
If running an extra cooler inline with the radiator, then remove one hose from the radiator and attach it to your new cooler, and then attach another hose to your cooler and attach it to the radiator
Illegitimi Non Carborundum
No, you can block the holes off in the radiator with the caps that are on the cooler so no crap gets in it, but you don't really need to.
hey there im putting a tanny cooler on my VP its ot stg2 shift kit would the holden tranny cooler be right to put on?
ok so i have put the top hose of the raditor the the cooler and then from the cooler to the steel hose on engine, is that correct? sory newbie to the Vp's as had a VH
Did you bypass the radiator? and just do the lines to the tranny cooler?
~ VN POWER ~ Click the scales
i left the feed line on the radiator and just put hose from top of radiator to cooler then from cooler to return hose in front of engine.
you might aswell plug the holes in the radiator and run 2 seperate lines from tranny feed and run it to the tranny cooler hooked up to the front of the radiator, that would be a better idea and alot neater.
Depends on how big the trans cooler isBut if it's fairly large, then that's a good idea
That's how my stato was set up before I chucked out the auto box
The 1972 HQ Kingswood
yeah thanks.
just went and got the extra house and set it up.
Sweet, upload some pics of how it turned out![]()
I always just ditch the cooler in the radiator, and just run the tranny hoses directly to the trans cooler....
This may be useful - about 1/4 the way down there is an image of trans cooler flow and some spiel about the value of retaining the cooler in the radiator side tank:
700R4 700R4 from PATC, 700 Raptor Transmission, 47RE, 47RE 48RE
