Hey guys, i have never had to jack the rear of my VP up before, i went to do it today, and there isn't those reinforced semi circles on the rear of the VP like there is on the VN. IT has them at the front, but not the rear. Where should i jack her up from in the rear??
Originally Posted by wikky
It should have the jack points...but you say they don't then just jack it up on that lip about the same distance back from the wheel arch the front has, its about 10cm?
It's weird, where they should be, there is like a half circle ring of steel thats welded to the body.
Weird, but they definantly aren't there on the rear. They are on the front only.......
My VP berlina has the rear ones between the doors, down the bottom. Directly down from the B pillar.
I don't know if all VP's have them where mine is or only the IRS cars, but the rear points on my VP are about half way down the car, not right near the back wheel like on a VN, dont try and jack it in some random place, you'll just bend the sill
Yeah i know screw trying that ^^^^ sills etc aren't reinforced to be able to take the cars weight as you well know.
I'll stick my head under and take a squiz in between the doors!
