Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: vp 5l missing sometimes + hard to start
    92 VP Calais International - RIP VR Turbo
    Jul 2005
    Echuca
    Default vp 5l missing sometimes + hard to start
    My vp calais 5l has been missing a bit lately while cruising ya feel it chug a bit and doesnt feel as powerful as it should be, it seems to run worse when the engine is warm.
    Also the car is hard to start, takes 2 secs to start usually and sometimes longer.
    Recently i've replaced plugs, dizzy cap, rotor button, fuel filter, oil and filter, and also run a bottle of nulon injector cleaner through and have tried different fuels and still the same thing occurs.
    What else could be causing the problem?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    have you adjusted the base idle lately??? you might of opened the throttle too much and the throttle plate is revealing the port for the charcoal canister and its purging fuel vapour into the intake manifold..... could also be the coil on its way out
    VP Executive R-spec
    Jan 2005
    Boonz's Avatar
    Jul 2005
    Jul 2005
    Echuca
    i have no charcoal canister....i just looked before and it has the 2 lines there but they have screws in the ends of em, passed rwc at 2 places like that though!
    Boonz's Avatar
    Jul 2005
    Jul 2005
    Echuca
    i dont understand how the charcoal canister works but yeah probably! lol i can smell fuel in the car sometimes maybe thats why
    Boonz's Avatar
    Jul 2005
    take out those screws and invest in a charcoal canister lol...... it ends up saving you petrol money by recycling the fumes
    Jul 2005
    Echuca
    yeah, so does the breather hose from the tank go to the charcoal canister, and the 2 lines from the tb? i'll have to see if all the lines are still there.
    car
    Jul 2006
    greensy, melb
    get some carby cleaner and give the throttle body a really good clean too, that might help a little
    "A life lived in fear is a life half lived"
    Jul 2005
    Echuca
    the throttle body is spotless, i went to clean it the other day since i havent cleaned it since ive had the car and its spotless
    Jul 2005
    Echuca
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by tysons_2001 View Post
    I'm thinking maybe a rooted coil or something?
    lol v6 boy, v8 has 1 coil, its the ignition coil which is in the inlet manifold kinda near the dissy, could be the ignition moduel, im no v8 expert see what you guys think
    Jul 2005
    Echuca
    also noticed that the monsta tacho had been goin crazy, like the signal is cuttin in and out for it, the dash tacho also does it a bit sometimes but not as bad as the monsta, guessing this would be linked to the same problem.
  15. #15
    VP 5L Calais
    Mar 2007
    S.A
  16. #16
    Jul 2005
    Echuca
  17. #17
    Boonz's Avatar
    Jul 2005
    theya re worth about $300-$600 depending wether you go genuine or not.... but id be playing swaps with someone elses before i went and bought one..... two bolts and a connector under the right hand strut tower
  18. #18
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    u can get a reco 1 from repco 4 $138 or brand new $400 mine just **** itself on thursday i played swapsies with a 2nd hand 1 it fired straight away but wasnt running right couldnt idle where it was supposed 2 in park and i had a loud knockin noise 2 so im waitin 2 get a reco 1 n see if that helps during the week
    2 replace its simply 2 bolts under the wheel arch and a matter of unpluggin 2 looms connected 2 it
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  19. #19
    Boonz's Avatar
    Jul 2005
    did you use any conductive grease under the body mounting surface? its critical that it has it there to stop corrosion
  20. #20
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I was thinking ignition module aswell.
    With the tacho, the problem is you have a perfectly good one in your dash now. Rip the monster tacho out and your problem will be solved
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  21. #21
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by Peanuts Inc. View Post
    sorry was this directed at me? if it wasnt i appologise but no i didnt i never got told 2 do such a thing?
  22. #22
    vn calais 5l
    Oct 2007
    kalgoorlie wa.
    have u tried ur timing. ur dizzy may not be tight enougth may be moving or has moved.
  23. #23
    Jul 2005
    Echuca
    Quote Originally Posted by STEALTHY View Post
    come with the car, dont wanna rip it out till i find somethin else to put there to fill the hole, dont like the idea of a hole in my dash.
    But i agree, why do ya need a tacho when ya got one in the dash already? and a shift light when its an auto?
  24. #24
    VP 5L Calais
    Mar 2007
    S.A
    hey i think i know what half my starting problems could be, my dizzy cap and rotor button are 30,000 thrashed driven hard as fu@k km's old, and my plugs about 25-30,000 of the same driving style (obviously). i also have 10mm top gun leads, will they be OK. i'm changing the plugs and dizzy cap/rotor though. also i'm gonna get a new coil.
  25. #25
    STEALTHY™'s Avatar
    Jan 2005
    Unless you run 10s, you don't need a shift light, cause you can hear the motor.
    I think you should go find the old owner and punch them for drilling holes in your dash.
    cheers sexy
  1. VP V6 Hard To Start - Help
    By oldfart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2010, 05:39 PM
  2. hard to start
    By ads72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 01:33 PM
  3. Vr Hard to start
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 08:14 PM
  4. hard to start!!!
    By dahlyla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 02:24 PM
  5. Hard to start
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2004, 02:30 PM
