Results 1 to 11 of 11
Thread: Auto gearbox problem
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    Default Auto gearbox problem
    Vn executive sw. Auto gearbox is quite harsh between 2/3. Seems to stick in second but eventually changes up. Any ideas on a cure?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    could be seals gone inside.
    try changing the oil but if it's internal, you might need to kiss it goodnight.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    have a play with the kick down cable if mates stuff around with it and dont no what there doing it will send it all stupid does it hold every gear? how fast do you have to go before it clicks 2nd 25km 35km?
    VN Executive
    Oct 2007
    Had another look and I was wrong. It's 1st to 2nd that sticks. Thought it was 4-speed but it only uses 4th as o/drive.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    yeah have a play with the kick-down cable. i cant remember if to loosen or tighen for lower change. just mark the cable with a texta or somewthing so if all fails you know how it was. but remember.. just one click/notch adjustment will make a big difference.
    btw, it is 4-speed. 4th is known as overdrive..
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VN Executive
    Oct 2007
    Well, tried adjusting the kick-down, today. First I tried the way the book says. Didn't seem to work. It says "Depress the metal tab and pull the outer cable away from the throttle linkage until the end of the cable contacts the adjuster fitting. Release the metal tab.
    Fully open the throttle valve. The cable will move through the adjuster fitting and automatically stop at the correct position when the throttle valve is opened fully."
    Doing it that way seemed to jam. So I tried to find some position by trial and error that would work. Now seems to be working much better but I still think there must be a simpler way.
    Has anyone a better way to set this?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    the way the book said is a good starting point in my opinion. then adjust to your liking.
    My (ex)Ride
    vp exec
    Nov 2007
    my car seems to be jumpin when u gun it till it gets a few revs up in first then it takes forever for 2nd to engage like as tho its slipin, had my car running great now this is happening and my car now feels useless in drags, what do u think this is or do i just hav to adjust the kickdown couse ure storie dont seem so differant. help i had a feeling it might be a bad batch of leads or plugs...
    vp exec
    Nov 2007
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by IvegotaCommy View Post
    If its jamming, dover it in WD-40 and then try again, let it get into its position and wipe off excess lube.
  1. VN s1 auto gearbox same as VP s2
    By stockhorse in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2007, 05:16 PM
  2. Auto Gearbox
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 06:12 PM
  3. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  4. wtb vr auto gearbox
    By WILD VR CLUBBY in forum Swap / Wanted to Buy / Trade
    Last Post: 12-08-2006, 12:12 PM
  5. auto gearbox
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2005, 12:13 PM
