Just wonderin if anyone can help m out? as the title says my S1 coughs on take off speeds, its nothing big, it will probs do it once or twice a day, but it gets frustrating when im tryin to whind her out. its around 2 or 3 coughs then she gets up and goes as she usualy does. anyone had this problem? cheers.
Could be anything ... crap in the tank , blocked fuel filter , leaking fuel hose , leaking injector o rings , blocked injectors , air filter dirty/blocked , need new spark plugs , throttle body needs a good clean, Check if fuel pressure regulator is leaking fuel or hose loose or damaged also check over all the throttle body hoses as sometimes they come lose and cause hell of alot og probs.
1st thing id try is...
id be spraying some carbie cleaner into throttle body to clean it and change fuel filter and air filter & maybe run a bottle of nulon total system clean costs like $20. If that doesnt help then try other options i mentioned.
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
cheers mate, i'll pick up some carby cleaner 2moro and give it a squirt.
are you getting an engine warning light?
nah no warning light mate, took off the throttle body 2day and gave it a clean. im thinkin it could be crap in the tank, do uno anything about the VN drop tanks? can u buy them or do u have to get them made?
on the other hand may just thrash it, and throw in a 5.0 and reco box lol
tried changing your fuel filter.
