Results 1 to 16 of 16
Thread: Problems with V8 TV on V6
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Question Problems with V8 TV on V6
    I got a V8 TB and i've put it on my V6, and the engine light comes up, i changed the sensors and its still the same. So i put my V6 TB one back on with the same sensors and its fine. I did paint it ( not the inside TB ) could that be a problem i could'nt see that it would be. Perhaps the sensors are different on V8s i didnt think they where. its off a VP V8.
    Thanx.
    Sorry about heading lol.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    it should go on fine. pretty sure the sensors are the same. did you also change the IAC, maybe thats faulty on the V8 TB? have you tried resetting the idle?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Black VN MANUAL
    Feb 2007
    Top of Vic
    when i had the V8 TB on i took it to the mechanic and got a comp[ test he said it was a sensor in there i changed the tps and still the same thing. i took the V8 TB off put the 6 Tb on with the same sensors off the V8 TB and it was fine, i have tryed adjusting the V8 1 but the engine light just stays on all the time wen the V8 TB is on there.
    VP Exec
    Jun 2005
    Which fault code is it logging? TPS?
    ALDL Information for the VN & VP Holden Commodore
    It's on the linked page but to spell it out, earth pin B; connect pins A and B and count the flashes of the "Check engine" light.
    skobs's Avatar
    skobs is offline 3.8L
    VP Exec 1992
    Apr 2007
    same thing happens to my car, but ive got a 70mm throttlebody, i posted a thread a few months ago, and someone told me to get my engine tuned. Might get a dyno tune done soon when i get my pacies in, other than that, if u find out its something else, let me know!!!! Cheers Dave
    rollin on ve ss rims
    Black VN MANUAL
    Feb 2007
    Top of Vic
    There must be other people out there with no tune running a V8 TB or bigger?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i'm waiting on a tune from paradox lol, see if that will help it or improve it.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    if you post an error code then we can tell you which part of the TB is ****ed...
    it could be a number of things.....
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Black VN MANUAL
    Feb 2007
    Top of Vic
    not sure how to test the codes. i got the code book dunno where to hook wires up never done it
    May 2005
    .....SE Burbs
    there is a how two in this site, in How to section.
    Your brdge a connecter with a paper clip and it flashes the code out...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    May 2005
    .....SE Burbs
    Checking error codes VR/VS (Revised)
    found it
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Black VN MANUAL
    Feb 2007
    Top of Vic
    VP Exec
    Jun 2005
    Or you can look at the page I provided a link to in post #4 on this thread, which is why I provided it.
    Apr 2006
    Auckland NZ
    i have previously run a 70mm TB without any fault codes showing. i removed it unfortunatly cause i had a problem with a sticking throttle which turned out to be a problem with the new larger butterfly not closing properly. currently making a new one so it should be back on in a few weeks hopefully
  15. #15
    Black VN MANUAL
    Feb 2007
    Top of Vic
    a mate said there is no point running a V8 TB cause of the elbow is smaller on a v6 and i have had a look and it is fine... no lip or anything.
  16. #16
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Bz Kn33z View Post
    i measured the elbow, it's about 68-69mm. nothing that can't be fixed by sweeping it out with a carbide cutter (if your going to a 70mm TB)
  1. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  2. VK problems - HELP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2006, 03:25 PM
  3. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 08:50 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 03:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 12:04 PM
