Hey guys how hard is it to put a B & M shifter in my vn ss i have purchased the B & M Pro Ratchet?
I now have a stage III trans rebuilt & 2500 stall,
just wondering how much some guys have paid to get the shifter installed,pics and info would be appreciated.
I would like to get this done asap.
i have included 2 designs i have thought about 1 being the statesman matts car,the other a vn with no consol setup,which i was thinking about tho cant run air con vents and i have a drama with carpet,cig light,elec window switches?
Cheers.![]()
* RVN 355 *
how much it will cost depends on where you take it really... mine was about 3 hours worth of work, and it's still not quite 100%...
you needa modify the shifter plate slightly (the rivetted in piece thinngie) - to make ita nice flush surface to mount to. I also welded a bit extra onto mine so the shifter could sit nicely and be mounted solidly (you don't want it coming out of the ground when you get excited)
You could also get fancy and modify that plate a bit more and actually recess the shifter body underneath the stock console - so it all looks pretty factory.
