Have had a look for this but didn't find. Maybe there but... Has anyone come up with a method that will tighten up sun visors especially the drivers side? Mine keeps falling down and is a b.... nuisance!
heat the bottom bit with hairdryer or gun then hold it up and let it cool,tightens it up a lil did this 2 mine
MY VY SV8 HBD http://forums.justcommodores.com.au/...y-sv8-hbd.html
i just pushed mine in against its joint cause it had slipped down al ittle and off of the teeth that hold it still.
Hair dryer idea is good.
um pull the shaft out of the visor and putt a lil tape around it to give it some girth.. squeeze it back in.. or go to pick a part and get 2 for like nothing $5 ea.. upgrade to vs ones with mirror
I got mirror stock, VS fails.
stock aswell carpeted ooh lala
Tried the tape idea. Didn't know what sort of tape so used some plastic insulation tape AND some masking tape. Seems to work well. Time will tell if it will last but tape is cheap and easy to change.
yer its just to give it that friction it needs to stay up after time the foam in the sun visor goes hard and it becomes loose loll so yer
